aftermarket water gauge wiring
i have bought a water temp gauge but have some problems regarding the wiring.
the gauge has 4 wires which are comming out:
yellow: that is a 12v
purple & orange : connect to headlamps or other 12volts
and black : ground.
till here all is fine, now this is were i got stuck.
on the back of the gauge there are 3 sort of bolts .
1 is ground
and there is one +
and another one S.
i also have a sender unit sensor which has 2 wires, 1 black and one white. now i suppose that one of them needs to connect to the S terminal on the gauge, but what about the other wire?
and black : ground.
1 is ground
and there is one +
and another one S.
the sender unit has 2 wires, 1 black and one white,
should i run the white to the S and the black to ground.
so the sensor itself dosent need any 12volts?
travis
Feb 10, 2002 09:39 PM
