lensos tubes and rim screws
Old Apr 10, 2011 | 11:14 AM
99blackdc2's Avatar
Default lensos tubes and rim screws
My rf slick has a pin hole in it....and new ones really arnt in the budget right now. A friend gave me tubes and screws and now I hav afew questions. Are you guys putting the screws front and back side? How many per side? The valve stem on the tube is larger diameter then the hole in the rim can I drill the rim larger or will the tubes not work. And last with a small pin hole do you think using the tubes is safe? Thanks guys never really used tubes
Old Apr 10, 2011 | 12:54 PM
Ls_dx's Avatar
Default Re: lensos tubes and rim screws
You dont have to have screws if you are just putting in tubes.
Old Apr 10, 2011 | 01:05 PM
SPOOLINmatt's Avatar
tubes are fine, but dont use screws unless you are spinning the tire on the rim. Wouldnt the screws puncture the tube anyways? 8-10 per side anyways
Old Apr 10, 2011 | 01:11 PM
sanman000719's Avatar
i have 10 screws on the outside only on my lenzos
Old Apr 10, 2011 | 02:40 PM
99blackdc2's Avatar
Valve stem on the tube is larger in diameter than the rims hole. Recommend drilling the hole larger or no?
Old Apr 10, 2011 | 02:48 PM
cluelessmale's Avatar
lubes and screws no issues, to run tubes you need to drill out the valve stem place to fit the larger sizes stem.
Old Apr 10, 2011 | 03:24 PM
99blackdc2's Avatar
Are screws really necessary with the tubes? Nervous about slick catching the tube while spinning and ripping the valve stem
Old Apr 11, 2011 | 05:55 AM
99blackdc2's Avatar
Anyone running tubes without the screws? I marked my slicks last time and after 2 seasons they moved maybe 2 inches off the marks... I don't want to drill my rims if I don't have to....thanks for all the help guys
Old Apr 11, 2011 | 06:13 AM
heavy duty's Avatar
If they move at all drill them.
Old Apr 11, 2011 | 09:36 AM
Ls_dx's Avatar
Old Apr 11, 2011 | 06:06 PM
99blackdc2's Avatar
drilled one and want to know if this angle looks right before i continue
OEMaccord
Jun 3, 2024 09:06 PM
v1crattlehead
Apr 1, 2009 09:30 AM
higgunscrx
Aug 12, 2008 01:50 PM
RACEPAK
11
Dec 11, 2005 03:03 PM
SOHC4life 96
Sep 4, 2004 04:30 PM
