looking for your option on which motor is better to turbo
Old Apr 10, 2011 | 08:55 AM
speedciv's Avatar
Default looking for your option on which motor is better to turbo
im looking to build a turbo car and new to the honda world. i dont know which motor is better im between a b16 or b18 which one is better to turbo on stock internals? also wht should the boost be at on stock internals? just looking for some ideas and insight before i start this project. thanks
Old Apr 10, 2011 | 09:05 AM
lunareg's Avatar
Default Re: looking for your option on which motor is better to turbo
b16's are better on the boost. boost pressure is relative to the turbo size, saying you can run 10psi means nothing without also stating what turbo will be pushing it.
Old Apr 10, 2011 | 09:14 AM
speedciv's Avatar
probably going to do a t3 t4
Old Apr 10, 2011 | 09:39 AM
EJeff8's Avatar
On a lot of engines 5-10 is about good on a stock engine with good looking internals. I had a friend who did 15 for a whole summer untuned, and through a rod clear through the block in the fall.
Old Apr 10, 2011 | 09:58 AM
vartok's Avatar
and im betting that if he had gotten it tuned, it probably wouldnt have through the rod.... If you put a turbo on an engine, you NEED to have it tuned. or you end up with a "block of swiss cheese"
Old Apr 10, 2011 | 10:27 AM
lunareg's Avatar
yeah I think so too, the tuner would determine if 15psi is more than the motor can handle and make sure everything was running perfect.
Old Apr 10, 2011 | 11:04 AM
speedciv's Avatar
i wasnt going to run more then 10 psi because its just gonna be my toy to have fun with just wasnt sure what motor was the best base but thanks alot you been a big help
Old Apr 10, 2011 | 11:11 AM
vartok's Avatar
right, because its not the PSI that blows motors, its running too much HP over when the parts can handle (assuming its a good tune)
Old Apr 10, 2011 | 11:13 AM
grumblemarc's Avatar
The Grumpiest
Before ANYTHING gets turboed or tuned you should FIRST get a compression test to make sure the engine is healthy and maybe even go so far as to install ARP headstuds to prevent headlift. B-series are good for 300+ horsepower on stock internals.
Old Apr 10, 2011 | 11:19 AM
93egSLEEPER's Avatar
GSR on 10psi t3/t4 57 trim gets my vote. Im curious why "b16's are better on boost". The added displacement makes more tq, which means more power and it spools the turbo quicker.
Old Apr 10, 2011 | 11:33 AM
The Grumpiest
Yeah. I don't get that one either.
Old Apr 10, 2011 | 11:48 AM
ReDHaTcHyGuy's Avatar
^ i think the guy that said that doesnt know WTF he's talking about.. LS or GSR are going to be better... with a GSR trans on either
Old Apr 10, 2011 | 11:53 AM
lunareg's Avatar
my bad, I didnt mean to say b16.. im on my phone. ideally you would want b16 head and b18 block, the b16 block is much weaker with no torque, but high revving head.
Old Apr 10, 2011 | 12:24 PM
speedciv's Avatar
yea i was planning to do a lsv so you think i should start with a b18? that would be my best bet for a starter turbo setup?
Old Apr 10, 2011 | 12:27 PM
The Grumpiest
Seriously. If you have to ask then you are no where near ready.
Old Apr 10, 2011 | 12:32 PM
speedciv's Avatar
im not ready because i asked a question? that makes no sense so many people have so many different options on the subject so that comment made no sense so i dont need your input
Old Apr 10, 2011 | 12:35 PM
The Grumpiest
Yeah. What do I know?
You have to research for quite sometime before you undertake a turbo install. Weeks or better yet months. Simply coming in here asking generic questions tells me all I need to know. You are not ready to go turbo.
Old Apr 10, 2011 | 12:42 PM
Shandles's Avatar
^^^agree'd
to turbo a car, you really need to know what you're getting into. The simple questions you're asking tells us that you're really not ready for such a big step. You need to do a little more reading and ALOT more understanding.
Old Apr 10, 2011 | 12:43 PM
speedciv's Avatar
about hondas nothing but idc i asked a quesiton i no the b16 has less compression ratio but obviously the b18 has a bigger displacement and i wanna do the lsv but since im not doing that right away i wanted to know a good base engine. theres nothing to be "ready" for i have a 1000 hp drag stang this is a cheap pos to mess around with so if you dont have anything good to say then dont
Old Apr 10, 2011 | 12:48 PM
speedciv's Avatar
lol there is nothing to turboing a car i asked this question to get input from ppl who have done this before on stock internals i can clearly go out a build a sick car but idc to do so
Old Apr 10, 2011 | 12:57 PM
The Grumpiest
I don't really care about your drag car.
What engine is best to turbo? Best for what? You can turbo a lawnmower engine if you want to. You have no goals. You don't know what horsepower you can run. You don't even know what's safe to run on stock internals for any given engine. You don't know anything about Honda engine whatsoever yet you come in dropping terms like LS-VTEC like that's supposed to tell us you've done your homework. "The B16 has less compression ratio"? WTF are you talking about? Less than what? Hell you can swap in and turbo an F/H-series, a K-series and a J-series if you want to.
And as far as I recall this is a public forum you posted to so I can pretty much post where I please. I see guys like you with your pipe dreams come in here all the time asking these exact same questions with no plan expecting everyone to spoon feed you every little detail and not do ANY research on your own. Guess what? They never follow through with anything.
You already admitted you don't know squat so why not be quiet and listen to what people are trying to tell you? Whether you like it or not.
Old Apr 10, 2011 | 01:05 PM
speedciv's Avatar
lolol oook no **** i dont have goals its a fun peace of **** nd because im not wasting my time looking up details nd i have no "pipe dreams" this is not going to be a race car so i have no dreams but ok thanks anyway
Old Apr 10, 2011 | 01:16 PM
phoxking's Avatar
ht can be dicks sometimes lol, but what they're trying to say is if you wanna run ls-vtec turbo..and no idea on the output don't do it as your first and waste money, but if you are interested here's the link..
https://honda-tech.com/forums/forced-induction-16/how-build-reliable-ls-vtec-turbo-250-350whp-2757533/
i say just stick with b18block b16 head, but if its your first time with hondas, why not get an LS motor(b18, much cheaper) and you can make good power with it going turbo..
Old Apr 10, 2011 | 01:18 PM
speedciv's Avatar
thank you phoxking thats all i wanted to know
Old Apr 10, 2011 | 01:38 PM
yea there are alot of people on here that are dicks.. they'll be quick to say search n00b! instead of using this information forum for what is meant for, to HELP people.. not everyone knows how to search properly or are experienced in using forums.. it would be nice if people could just give an answer to people questions and actually try and help them
