94' Civic EX - Alternator fit problem
Old Apr 10, 2011 | 08:30 AM
sspatriots's Avatar
Default 94' Civic EX - Alternator fit problem
Hi,
This is my first time here. I've removed my alternator yesterday and picked up a replacement from AutoZone. For some reason the space between the mounting flanges on the new alternator is different due to a bushing that has been pressed in from the inside before assembly. I took it back to AutoZone and they said it is the correct alternator for my car and that I could either file off the bushing to that protrudes about .06" or drive it back with a hammer so that it will fit in the gap on the engine blocks mouting bracket that is at the bottom of the alternator. Just wonder if anyone has run into this and how they made it fit before I start filing or hammering on this thing.
Regards,
Steve
Old Apr 10, 2011 | 05:19 PM
mattl15's Avatar
Default Re: 94' Civic EX
IMO i would take it back and find an OEM one
Old Apr 10, 2011 | 05:21 PM
ReDHaTcHyGuy's Avatar
does your car have the stock motor?
Old Apr 10, 2011 | 06:07 PM
Former User's Avatar
Default Re: 94' Civic EX - Alternator fit problem
Please create more informative thread titles - edited.
Originally Posted by sspatriots
...or drive it back with a hammer so that it will fit in the gap on the engine blocks mouting bracket that is at the bottom of the alternator.
I had the same problem and did this^. Worked fine.
Old Apr 10, 2011 | 06:10 PM
boostedef123's Avatar
x2 on this. Happened to me also. It just happens wont hurt anything to tap it back in.
Old Apr 11, 2011 | 03:29 PM
sspatriots's Avatar
Yep, I ended up tapping it down with a hammer. Put larger diameter washer over it so as not to damage anything and make it be completely flat. Worked like a charm. Didn't want to take the alternator back because it had a lifetime warranty from AutoZone.
Regards,
Steve
Veleno
Apr 15, 2006 03:03 PM
goingtobefast
Dec 8, 2005 09:35 PM
