Can not fix this cut out problem! Please help (b16a)
Old Apr 9, 2011 | 07:22 PM
BootLip's Avatar
Default Can not fix this cut out problem! Please help (b16a)
I have a 94 civic ex with a jdm b16a. It has a chipped p28 ecu. I had idle problems and replaced and calibrated the tps(.4 closed 4.3 wot). Cleaned the IACV and FITV and all idle issue were solved.
However i happen to noticed a orange wire(pin4) on the distributor was cut. I reattached this wire. After i did all these things now the car cuts out at around 3500rpms almost like its hitting the rev limiter. Limp mode maybe?? The car had the CEL on before i did anything and currently does as well. When i do the cel jumper the cel stays solid (code 0). Which is a G101 code(ECU code).
I have tryed disconnecting the wire, reconnecting it, batt reset, you name it. Nothing seems to fix this cut out problem. I did notice that the distributor was missing one of the 3 bolts and one of two holding it in place was very loose. Could the dizzy have shifted and caused this problem? It still idles fine and drives fine below 3500 rpms,
PLEASE HELP or im gonna burn this damn car to the ground! (jk)
Old Apr 9, 2011 | 07:55 PM
lunareg's Avatar
Default Re: Can not fix this cut out problem! Please help (b16a)
It sounds to me like your dizzy has gone out of whack, I would definitely start there. code 0 is bad ecu, which can sometimes just be a bad ground, or loose wire
Old Apr 9, 2011 | 08:03 PM
Tyla12's Avatar
it has o be the back sensor plug on the intak mani mine did the same exact thing ano forgot i unplugged then plugedit in nd it was fine
Old Apr 9, 2011 | 09:28 PM
lunareg's Avatar
yeah thats something to look at too, ive plugged those wires in the wrong spots back there when i was clean my iacv before
Old Apr 9, 2011 | 09:33 PM
cetcivic's Avatar
no one wants to hear the truth
isnt the tps supposed to be calibrated at .5?
Old Apr 10, 2011 | 04:36 AM
HondaPartsHero's Avatar
Technical Hero
I would try another ECU and go from there.
Old Apr 10, 2011 | 04:38 PM
BootLip's Avatar
*Update* Decided to check the CKP,TDC, and CYP resistances on the distributor plug and i got these readings.
CKP-401 ohms
TDC-416 ohms
CYP-402 ohms
Are these normal???
Old Apr 10, 2011 | 07:21 PM
BootLip's Avatar
Default Distributor resistances question? (CKP,TDC,CYP)
JDM B16A in my 94 ex. Trying to figure out why my car is in limp mode. Got a CEL o (zero). Here are the measurements i got off my dizzy. Are these in spec?
CKP-401 ohms
TDC-416 ohms
CYP-402 ohms
Old Apr 11, 2011 | 06:08 AM
Sonia's Driver's Avatar
Default Re: Distributor resistances question? (CKP,TDC,CYP)
Yes that is within spec.
If you want to rule out the wire harness as well, you can disconnect the ECU and measure the wires from there, as well as measuing for continuity beween the wires and ground.
Old Apr 11, 2011 | 08:28 AM
Former User's Avatar
Bad distributor sensors would not throw CEL code 0.
Old Apr 11, 2011 | 07:42 PM
BootLip's Avatar
Default Possible causes for CEL 0?
Can not get rid of code 0! Please can someone tell me some possible causes of a cel 0. I know it has something to do with the ECU. Anything to test?
Thanks for any help!
Last edited by Former User; Apr 12, 2011 at 07:42 AM. Reason: UInnecessary non work safe language deleted
Old Apr 11, 2011 | 07:44 PM
BootLip's Avatar
Default Re: Possible causes for CEL 0?
Oh yeah. its a 94 civic ex, jdm b16a, chipped p28 ecu.
Old Apr 11, 2011 | 07:46 PM
Did you read the CEL sticky? Any problems besides code 0?
Old Apr 11, 2011 | 10:29 PM
mik101's Avatar
Only times I've seen code zero (that the ecu wasn't bad) was when the eeprom was corrupted or written wrong (in the case of vehicles using 512kilobit eproms instead of 256kilobit).
Or some components may need to be resoldered if you recently chipped it.
If you have access to another ecu to try, do that. It'll narrow things down in a hurry.
Old Apr 12, 2011 | 05:59 AM
BootLip's Avatar
Yes i have read the sticky. According to the sticky it sounds like the car shouldn't start at all with a cel 0. But it starts are runs fine(below 3500rpm). I know code 0 is a pwr/ground issue with the ecu. I will check the G101 ground on the thermostat tonight. Is there anything else to check to possibly fix this cel 0???
Old Apr 12, 2011 | 06:05 AM
Code 0 signifies an ECU power/ground problem only if the engine won't start and run.
If you have code 0 and the engine runs, then check for a short in the CEL Grn/Orn wire or service connector Brn wire or an open in the service connector Grn/Wht wire. If those are fine, swap in a known good ECU.
Old Apr 12, 2011 | 06:59 AM
BootLip's Avatar
I don't think there is a short in the wires. Because when i jumper the wires in the two pin connector it causes the srs light to consitantly flash for whatever reason. Any idea why the srs light flashes?
Old Apr 12, 2011 | 07:31 AM
This rules out a bad service connector wire but not a short in the CEL wire.
The SRS system (airbags) has its own computer. When there is an SRS error, you pull the SRS codes by jumping the service connector, just as you would do to pull CEL codes. The SRS light then blinks the code(s). For more information, check the SRS section in the FAQs sticky.
Old Apr 12, 2011 | 08:43 AM
BootLip's Avatar
Where do i find the CEL Grn/Org wire? Do i just test to see if its shorted to ground(continuity test)? Or shorted open? Like from where ever i find the grn/org wire to the which ever pin the grn/org wire goes into the ecu?
Thanks
Old Apr 12, 2011 | 08:56 AM
It runs between the cluster and the ECU.
Yes. Unplug the cluster and ECU and check for continuity to body ground at the cluster plug terminal.
Old Apr 12, 2011 | 10:27 AM
BootLip's Avatar
Default Main relay question?
1994 Civic EX/B16A. Iv read a lot about the honda main relay however im not 100% sure about something. Is it possible to have a bad main relay and still have the car start and run however stay in limp mode? Isn't there an ECU ground wire that attaches to the main relay? Could just a portion of the main relay fail?
Old Apr 12, 2011 | 10:29 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Main relay question?
Is this related to your CEL code 0?
Old Apr 12, 2011 | 10:54 AM
BootLip's Avatar
Well maybe... idk. im about to leave work and check/try a few things. I know the car is in limp mode for sure. I believe im getting code 0 however i am going to check the grn/org cel wire for a short.
Old Apr 12, 2011 | 10:57 AM
The Grumpiest
Sounds like you're just grasping at straws now considering this is your 6th related post for the same issue.
Old Apr 12, 2011 | 11:54 AM
94EG8's Avatar
Seagull Management
Correct. They'll throw codes 4, 8, and 9 depending on which one is bad.
Also, related threads merged.
