Suspension & Brakes Theory, alignment, spring rates....
Integra GSR Sway Bars on a Civic Coupe???
Old Apr 9, 2011 | 07:19 PM
boostjunkieee's Avatar
Default Integra GSR Sway Bars on a Civic Coupe???
Will Integra GSR front and rear lower sway bars fit on a 95 Civic EX coupe?
Old Apr 9, 2011 | 07:45 PM
90_EX_Civic's Avatar
Default Re: Integra GSR Sway Bars on a Civic Coupe???
yes.
will it be plug and play... not for the rears. unless you have the lower control arms and all the hardware to make it work for the rear.
Old Apr 9, 2011 | 11:56 PM
abs0Lut's Avatar
frankly yes, but youll need a few things: adjustable endlinks and rear subframe brace(prevents tear out, not necessary but its not worth the risk without it), you'll need the GSR rear lower control arms(or any aftermarket EG LCA's) aswell.
Old Apr 10, 2011 | 09:39 AM
So the front is a direct bolt on? No added hardware needed?
Old Apr 10, 2011 | 11:15 AM
98civdx's Avatar
Master Detailer
Actaully no he doesn't need adjustable endlinks, there is noithing wrong with OEM, he doesn't need a subframe brace. A non ITR runs a 14mm RSB, noithing the civic subframe can't handle.
He doesn't need GSR LCA's, ANY DC control arm will work, with the exception for ITR. The ITR LCA will work, however you must run ITR shocks.
He may even have the holes in the LCA's already.
OP, you can use what comes out of the integra, hardware, etc. EG/DC suspension parts are interchangeable. It will be bolt on.
Old Apr 10, 2011 | 11:19 AM
abs0Lut's Avatar
I've heard of people using stock endlinks, personally I would go with adjustable but it's up to the owner.
As far as the LCA's go I know they are all the same so I just used GSR as an example.
Old Apr 11, 2011 | 05:17 AM
Libertariat's Avatar
Ek Forever y0!
If you do decide to get aftermarket endlinks, splurge and spend the ~$50 on function7 endlinks. Solid company who spends years on RND on it's products. Well worth their design and quality focus.
Old Apr 11, 2011 | 12:52 PM
98civdx's Avatar
Master Detailer
^ THAT!
I bought blox, $90 mistake
Old Apr 11, 2011 | 01:25 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm pretty sure F7 does not make their own end links but rather sources them elsewhere. They are not listed under products on their site. I may be wrong but I will verify.
Old Apr 11, 2011 | 02:21 PM
98civdx's Avatar
Master Detailer
This is from F7 regarding the endlinks.
[/QUOTE]
We don't list them because we don't really "make" them. They are standard off-the shelf components for our endlink kits. Because of company policy I cannot reveal where we get the parts from and I cannot confirm nor deny that they come from Aurora -- and we do get them from multiple sources.
Our endlinks use teflon-lined bearing joints so they should be a little quieter but they do wear down over time and may become a little noisier. Still, we recommend keeping them oiled (WD40 works nicely) to protect them from the elements.
-A[/QUOTE]
Old Apr 15, 2011 | 05:07 PM
Function7's Avatar
Correct, we do not manufacture any of the parts that go into our endlink kits. We started to do this as a convenience to our customers when we first started selling our arms.
The main parts that go into the endlinks are standard metric rod ends and they come from several different reputable US-based industrial/aerospace parts suppliers. We then add the bolts and nuts and sell them as a kit.
-A
dj theoretic
Oct 30, 2008 08:29 AM
no_money2supe
Suspension & Brakes
Sep 13, 2006 03:22 AM
tsjeff
Jun 10, 2006 03:02 AM
killerboots
May 26, 2003 07:55 AM
deftones0817
Oct 18, 2002 08:22 AM
