99 Accord 4dr 4cyl trouble starting
Old Apr 9, 2011 | 12:32 PM
engtaz's Avatar
Default 99 Accord 4dr 4cyl trouble starting
I have a 99 Honda Accord that has trouble starting the on 1st try. Sometimes it takes as many a 7 tries before it starts. It will start eventually but takes a number of tries to get it started. Any idea's. It runs very well after is it starts up.
Thanks,
engtaz
Old Apr 9, 2011 | 02:14 PM
phootbag's Avatar
Default Re: 99 Accord 4dr 4cyl trouble starting
Need more information on what is happening during the no-start condition. Define, "tries".
Old Apr 9, 2011 | 02:39 PM
engtaz's Avatar
Try to start then shut off immediately.
Old Apr 9, 2011 | 02:47 PM
phootbag's Avatar
Could be a faulty main relay. Could be a faulty ignition switch.
If, when the vehicle doesn't start, you turned the key to the 'ON' position and did NOT hear a click from behind the dash as usual when the check engine light went out, the main relay could be at fault.
If you can wiggle the key in the ignition while in the 'ON' position in a manner that would not normally cause the ignition to turn off but it DOES, the ignition switch could be at fault.
Old Apr 9, 2011 | 02:48 PM
phootbag's Avatar
"Wiggle" meaning rotating the key slightly toward the 'OFF' position. Faulty ignition switches will be in the 'OFF' position when the key is in the 'ON' position because they get worn or contaminated.
Old Apr 9, 2011 | 10:30 PM
engtaz's Avatar
It usually harder to get started when it's hot, don't know if that info helps.
Old Jun 10, 2011 | 03:54 AM
engtaz's Avatar
The new ignition switch fixed a bunch of problems.
Thanks
Old Jun 10, 2011 | 01:39 PM
phootbag's Avatar
Thanks
Glad to hear it. Posting a fix is important because it helps make this forum a useful resource for people searching for solution to their problems.
honkylion
Aug 7, 2013 07:28 AM
shortyj46
Jun 29, 2013 06:58 PM
Aesthetic Gains
Jul 11, 2012 04:55 PM
jv971973
May 24, 2011 12:41 PM
InvaderTrax
Mar 1, 2007 09:39 AM
