Built LSVTEC Del sol
Old Apr 9, 2011 | 10:41 AM
BlueVxIDelSlo's Avatar
Default Built LSVTEC Del sol
I have a fully built lsvtec in my del sol and when i go to start it, the starter pops out and whines, but it turns the motor. BUT it is a constant whine. not the normal honda "br-br-br"
there are strong puffs of air coming out of the exhaust ports, so i feel it has compression.. but it just doesnt sound like a normal engine turning over. so thats my first issue. gonna recheck timing...AGAIN...
second, i have fuel to my fuel rail and my fuelpump primes, but my injectors arent spraying. they are precision 780s and i have my resistor box wired up correctly. just wondering what else could cause them to not spray.
just need some other brainpower other than my own
Old Apr 9, 2011 | 04:43 PM
Default Re: Built LSVTEC Del sol
bumppppppppppp
Old Apr 9, 2011 | 07:33 PM
i pulled code 16 from it which is my injectors... they are precision 780's with my resistor box hooked up correctly.. idk why they arent spraying... they worked fine with my buddys car, but he upgraded to 1000's and gave the 780's to me.
Old Apr 9, 2011 | 07:35 PM
turbojdmhatch's Avatar
chipped ecu? you need an ecu that will work with your 780cc injectors
Old Apr 9, 2011 | 10:19 PM
My ecu was tuned with 660s but I can't find 660 injectors so Brian gave me his chip for the 780s I have mikes old ecu :p. Help me hodgekins!!!!!!!!!!!
Old Apr 10, 2011 | 05:41 AM
i woulda started it with the stock injectors and stock ecu first.
Old Apr 10, 2011 | 06:58 AM
Deetz's Avatar
Crazy Honda Guy
This car must be boosted, because all motor, 780 cc injectors would be overkill
Old Apr 10, 2011 | 05:33 PM
yes its boosted and i dont have a stock ecu brian said it would be fine with the 780s
Old Apr 10, 2011 | 09:27 PM
someone most going foing for their G.E.D.
Old Apr 10, 2011 | 10:35 PM
Wdpfreak145's Avatar
I think what you meant to say was, "someone must be going for their G.E.D." And that someone should probably be you. Lol purely joking though.
Old Apr 10, 2011 | 10:43 PM
raidacaipo's Avatar
No it wouldn't be him.. A person going for their G.E.D is more intelligent. I would say someone like him trying to tell someone else about getting their G.E.D. but can't even put it in a simple sentence structure is likely graduating from elementary. I'm just saying..
Old Apr 12, 2011 | 07:55 PM
lolz anywhos..... i adjusted my valves and i have compression now lol. and we fucxed with the fuel sytem and got my injectors to spray... now it turns over and almost starts.. almost there haha gonna check dist. placement and whatnot
any other ideas?
mikegyverone
Dec 2, 2013 09:11 AM
cmwalker
May 21, 2013 04:49 PM
thatcivic96
10
May 29, 2011 04:33 AM
94jdmsol
Jan 6, 2003 09:14 AM
