Does an ACT clutch need an ACT pressure plate?
Old Apr 9, 2011 | 08:39 AM
dunked dc's Avatar
Default Does an ACT clutch need an ACT pressure plate?
Recently my car stopped going into gear. i replaced the clutch master cylander and slave cylander and no luck, jus did the thro out bearing a few weeks back and that is all good. I bought a new ACT 4 puck clutch for it and then it turned out i had a brokin tooth on my pressure plate. I have another b series pressure plate but my friend is saying ACT clutches are Special clutches that require special pressure plates. Anyone know if this is a true fact? or will the clutch work with a stock b16 pressure plate?
Old Apr 9, 2011 | 11:06 AM
EnjoyTheRideDC2's Avatar
Default Re: Does an ACT clutch need an ACT pressure plate?
Pressure Plates have "teeth"?
ACT clutch discs will "work" if paired with an OEM pressure plate. How well the combination works is another story.
eg customs
Nov 7, 2008 09:28 AM
spets
Apr 18, 2008 11:55 AM
SuicideSlide
11
Aug 29, 2004 01:25 PM
GraphiteAccord
Feb 12, 2003 10:56 AM
