White smoke, losing oil, and oil in coolant reservoir
Old Apr 9, 2011 | 01:55 AM
DRoylflush's Avatar
Default White smoke, losing oil, and oil in coolant reservoir
I have this same problem, but there is oil in my coolant overflow bottle. My car is not overheating. The oil is burning and I have white smoke that blows out the tail pipe at high rpms. Some loss of power as well, but no coolant in the oil! Any help would be greatly appreciated. I need to know if it could be blown head gasket or if it could be seals. I am searching everywhere for an answer. Also I took the high flow pipe off and put a catalytic converter back on!
Old Apr 9, 2011 | 06:34 AM
Former User's Avatar
Default Re: White smoke, losing oil, and oil in coolant reservoir
The head gasket is almost surely blown.
Old Apr 9, 2011 | 08:36 AM
Burton7706's Avatar
^agreed
Old Apr 9, 2011 | 08:49 AM
JdmCoupe91's Avatar
Oil in coolant is the most surefire way to tell that you're having a head gasket issue bro...
As well as white smoke.
Old Apr 9, 2011 | 12:31 PM
lunareg's Avatar
Old Apr 9, 2011 | 01:38 PM
DRoylflush's Avatar
When I bought the car from my buddy he said the car had the head gasket replaced a year or two before I bought it from him. The smoke is present when the vtec kicks in. i heard something about valve seals, etc. could I use the blue liquid head gasket repair? or is that a bad way to try and fix it? My car runs and drives fine, just loss of power (not total loss but noticable). I am burning a lot of oil, could it be wear on the pistons and rings? what would be the best fix?
Old Apr 9, 2011 | 01:49 PM
Again, the head gasket is the prime suspect. Do cylinder compression leak down tests.
Old Apr 9, 2011 | 05:29 PM
DRoylflush's Avatar
how would I do the leak down test? Is there a tool I can rent from the zone? (not sure if I can spell it all the way out still new)
Old Apr 10, 2011 | 12:43 PM
DRoylflush's Avatar
Ok so I bought some stuff I'm going to see if it works. If not, then I guess it's time for a new engine!
Old Apr 10, 2011 | 12:56 PM
93egSLEEPER's Avatar
If its just the HG no need for a new motor...just the gasket. Don't band-aid it, that will cause greater problems down the road. Also valve seals wont effect coolant and oil mixing. Its the HG.
Old Apr 10, 2011 | 02:05 PM
cetcivic's Avatar
no one wants to hear the truth
Cracked sleeve??
Old Apr 10, 2011 | 02:11 PM
OMGrimmy's Avatar
i hope you didnt get that headgasket fixer **** from walmart that claims it fixes headgaskets, it surely doesnt, it completely ****ed my ls/v in my old teg
a3k
Jul 26, 2009 10:36 PM
ericstambaugh07
Jun 25, 2007 09:08 AM
ericstambaugh07
Jun 24, 2007 07:49 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
sambam27
Dec 5, 2004 09:39 AM
