will these fit?
will civic hatch/ crx zc headlights fit my 89 ef sedan?
here is the link to the headlights
http://passwordjdm.com/JDM-EF-Hatchb...P2627C110.aspx
so i pretty much need to buy the zc nose cut just to get the zc headlights to fit, and are these ones plastic and single h4 bulbs?
link for the nose cut
http://passwordjdm.com/JDM-EF2-88-91...P1220C119.aspx
do you know the difference between the EF front end 90 model and the ZC front end?
a ZC front end is pretty much identical to USDM 88-89 model crx/civic. the EF 90 model is the JDM one that is most popular (civic hb and crx models have wrap around bumper lights).
to get the ZC headlights on your car (assuming its a stock 88-91 USDM model) all you need are the lights, thats it. then you just have to worry about the wiring conversion (if you need a plug n play jumper i can make one for you, just pm me). no need to buy the nose. also the most common zc headlights are plastic, but there are some glass ones out there.
no they will not fit. the 90 spec model is the EF8/9 model where the headlights are 1" longer than usdm model front ends. the second link he posted are ZC model headlights, which WILL fit the USDM front ends.
there is a big difference between zc and sir front ends bro i owned both
90 jdm spec as labed by the clowns of passwordjdm will fit a usdm front end why because they are the same size as the usdm only thing that differs from the 88-89 jdm is that they 88-89 use a metal bracket to bolt on and 90-91 dont use a bracket since they have tabs
yes the 88-89zc front bumper to the 90-91sir bumper are different
another thing the 88-89 use the metal bracket for the corners so they could be screwd on on the fenders while the 90-91 use tabs and a screw on the non bracket headlights
pics are at the top 88-89 zc middle90-91 zc bottom 90-91 sir headlights
so after everything i can use the zc headlights that i linked first then? or am i wrong, bc my friend has the zc 90 spec ones on his hatch, so ill just test fit his before i buy the ones off password
you can bro yes they will fit only thing your gonna have to do is change your corner lights since they mount differetly if i was you i would get the 88-89 the ones with the metal bracket since its direct fit but good luck post some pics when your done
slammedef06
Aug 27, 2005 03:02 PM
