CEL on start up occasionally
Old Apr 8, 2011 | 06:34 PM
DallasTEK's Avatar
Default CEL on start up occasionally
I just got this car, and sometimes it starts and chugs a little bit and the CEL comes on until I turn the car off and back on.
Stays off with a normal start up, comes on with it starts and chugs.
Also when I get gas and unscrew the gas cap there is a lot of pressure in the tank. Let's out that whoosh of pressure. Does this mean my EVAP system is not working?
Old Apr 8, 2011 | 09:28 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: CEL on start up occasionally
Jump the blue connector at the glove box and find out what the code is. That will direct you to what the problem may be.
Old Apr 9, 2011 | 11:41 AM
quickster's Avatar
There is supposed to be pressure.
Old Apr 9, 2011 | 01:00 PM
DallasTEK's Avatar
Problem with trouble shooting the code is, it's not always on. Only when it has a rough start. That's usually only after it has set for a long while.
Also I was under the impression that if there is excessive pressure in the gas tank, the evap control valve may be busted?
Old Apr 9, 2011 | 02:13 PM
phootbag's Avatar
PULL THE CODE!!!! The Trouble Code will tell you what circuit the computer saw a problem with. I'm betting it's a low-idle code.
Old May 1, 2011 | 10:00 AM
DallasTEK's Avatar
So here is a update. Problem has progressed into making the car not start sometimes. Will act like it's about to fire up and just immediately puffs out.
Okay finally got codes.
22 VTEC pressure valve
And
9 CYP - cylinder sensor
Are these legit? Could they cause my problem?
Where can I get a new vtec pressure valve? Mine is all rusted up and the plugs is all beat up.
Distributors hard to install?
Old May 1, 2011 | 05:17 PM
DallasTEK's Avatar
anyone?
Old May 2, 2011 | 03:59 PM
poorman212's Avatar
Starting-a bad crank sensor,yes. Installing a dist, not hard as long as you make sure to mark everything...dist to head and where rotor is pointing.
Pressure switch-dealer.
cjwang2
Apr 16, 2015 06:22 AM
bopbop93030
Nov 8, 2008 03:02 AM
RDAYA0
20
Apr 8, 2008 08:56 PM
dcfour
Apr 4, 2005 06:34 PM
gooknom
May 3, 2004 07:49 AM
