CRX HF (Ideas on what to mod)
Old Apr 8, 2011 | 03:32 PM
r90crxhf's Avatar
Icon2 CRX HF (Ideas on what to mod)
I have a 90 HF 1.5 8 valve... Ive been wanting to add real mods so it can run a little more.. so far I just have a cold air intake and full exhaust system icluding headers... just wondering if theres any suggestions on what else I could add... (some cheap/effective mod's??) :/
Old Apr 8, 2011 | 03:38 PM
sinaloa_ef's Avatar
Default Re: CRX HF (Ideas on what to mod)
best thing to do would be swap it out and put a b series motor in there that would be your best bet because its only 8 vavle
Old Apr 8, 2011 | 04:07 PM
r90crxhf's Avatar
out here its kinda hard to find a b series engien let alone a good/working one... would a mini me swap help.. is it worth it? what would I need to getapart from the heads? would an ecu help? and wich ones better? lol I know this is noob questions but Im kinda getting started here!
Old Apr 8, 2011 | 07:48 PM
Kron1116's Avatar
You could buy an ebay SOHC turbo kit, cheap and fast.
Or upgrade things like pistons or a camshaft with higher compression/lift.
Old Apr 8, 2011 | 08:15 PM
nateef9's Avatar
mini-me's are good for just little hp gains. i would get a y8 head and head gasket if your doing a mini-me. you will need an si ecu and dizzy if you want to stay obd0 then just chip and tune it with turboedit or megasquart.
Old Apr 8, 2011 | 08:21 PM
crxguy406's Avatar
Gas is supposed to hit $5+/gal this summer... id keep that bitch stock, lol. (I'd love to find a good-running HF myself.)
Old Apr 8, 2011 | 08:53 PM
D16SiHatch's Avatar
good lord there is a lot of crap half-assed info in here. Don't waste your time or money upgrading anything internally on that engine, you will never make dick squat worth of power out of it. Also, i wouldn't bother trying to boost it, it would not respond well to that. Since you're just getting started i would not swap engines just yet. I would start with something a little less complicated like a mini-me. google search mini-me swap and you will find lots of info. the basics include a z6,y8, or d15b head, obd0 to obd1 ecu jumper, and a p28 ecu. If you have any specific questions concering the swap, just ask. Also,
Old Apr 8, 2011 | 10:30 PM
Nooch's Avatar
ME: I'd leave it stock, **** I'd kill for a stock HF right now.
YOU: Spend it on suspension/brakes. You'll at least not kill yourself or someone else later on. Egay boost won't do **** by the way, as will the turbo just explode in your face 50% of the time with ebay trash.
Old Apr 8, 2011 | 11:02 PM
.Manny.'s Avatar
Touching My Member
Like others have stated...Suspension, bushings, brakes, seals, tune up. Enjoy the mileage!
Old Apr 9, 2011 | 12:16 AM
r90crxhf's Avatar
ok ok I get it mini me swap if I want HP... but I also understeand the engien has not much potential.. lol anyways suspension upgrades sound good and if any mini me swap questions sur to ask for help here! (d16sihatch)
Old Apr 9, 2011 | 04:09 AM
white90crxhf's Avatar
I don't think an mini-me will work with an HF block, if i remember correctly the pistons were made for a head with 8 valves, not 16.
Old Apr 9, 2011 | 10:10 AM
KillerHippy's Avatar
Yep. Here's a picture of my d15b6. As you can see there's clearance for only 2 valves on each piston.
Old Apr 9, 2011 | 10:20 AM
HeadlesNorseman's Avatar
correct, minime will not work on an HF. I have an HF and im swapping it out only because i want the motor/trans for an EF civic hatch(need the seats) and the CRX is just going to be a fun car. I have a b18b sleeved block with forged pistons and a b16 cable trans = fun) My best advice would be to just find a crx SI trans. Sure its not going to have more power, but it will make a huge difference in the fun factor of the car. And then later on you can swap to a d16 or sohc vtec motor. The HF tranny is also worth a good bit, ive been offered 3-400 several times for mine even with 200k on it. Its a rare item
Old Apr 9, 2011 | 03:40 PM
r90crxhf's Avatar
funny??.. I always thought my HF was an 8 valve... How can I find out how many it has?
Old Apr 9, 2011 | 03:56 PM
r90crxhf's Avatar
1988-1991 Honda Crx HF
Displacement : 1,493 cc (91.1 cu in)
Bore and Stroke : 75 × 84.5 mm (3.0 × 3.33 in)
Compression : 9.1:1
Power : 62-72 hp
['88-'89] 62 bhp (46.23 kW, 62.86 ps) @ 4400 rpm
'90-'91] 72 bhp (53.7 kW, 73.0 ps) @ 4500 rpmTorque : 83 ft·lbf (11.5 kg/m, 113 Nm) @ 2200 rpm
Valvetrain : 8-Valve SOHC
Fuel Control : OBD-0 MPFI
Head Code : PM-8
Old Apr 9, 2011 | 03:57 PM
r90crxhf's Avatar
72HP lol
Old Apr 9, 2011 | 04:31 PM
j3wman's Avatar
id upgrade to at least a d16a6 since that at least broke 100hp and theyre hella cheap. if you want something particlarily nice get a z6 or y8 engine with a si cable tranny
panaphobic
10
Jul 3, 2007 02:44 PM
1990hondacrxhf
May 4, 2007 01:59 AM
h22squeaker
Apr 6, 2004 07:01 PM
JDMfan
Mar 2, 2003 06:00 AM
lilcasino
Oct 18, 2002 05:47 PM
