91 civic ef cuts out
Old Apr 8, 2011 | 02:51 PM
jasongeist's Avatar
Default 91 civic ef cuts out
when i turn my brights on and give it gas my car act like im hitting a rev limit and when i turn them off then my car takes off flip brights again hit rev limit
Old Apr 8, 2011 | 03:27 PM
4drEF's Avatar
Keyboard Humorist
Default Re: 91 civic ef cuts out
Do you have stock headlights and stock wiring?
Sounds like you might have installed HIDs and you don't have a fuse installed.
When you turn on the brights, something shorts out and you have major power issues that want to stall your engine.
Do you get any check engine lights? Blown fuses?
Old Apr 8, 2011 | 03:32 PM
jasongeist's Avatar
i have hids that plug directly into my factory headlight plugs but i had same problem when i had stock head lights. and it acts the same way when i blinker
Old Apr 8, 2011 | 03:33 PM
jasongeist's Avatar
i do have the b16a swap in it to
jasongeist's Avatar
and yes i have the stock wireing cuz its an older b16a so everything pluged in
Old Apr 8, 2011 | 03:52 PM
4drEF's Avatar
Keyboard Humorist
can you remember if the problem started after you did something to the car?
anything else make this problem happen?
so far - high beams and when ever you use the blinkers.
Old Apr 8, 2011 | 03:55 PM
jasongeist's Avatar
just those 2 things happen and it only happens when i flour the gas all the way with those on. and i bought the car with the swap and it was like that
Old Apr 8, 2011 | 03:59 PM
blue91EF's Avatar
ef never came with bseries as far as i kno so the ecu & wiring isnt stock.
the wiring isnt done correctly it sounds like. could u take an underhood pic?
Old Apr 8, 2011 | 05:04 PM
jasongeist's Avatar
its obd0 but i do notice that some wires are not hooked up but everything works besides the problem iv told u
Old Apr 13, 2011 | 05:44 AM
jasongeist's Avatar
It was my cluster gauge that was the problem
Old Apr 13, 2011 | 09:14 AM
JOE BD-0's Avatar
Please explain so we all can learn something here.....Thanks......
Old Apr 14, 2011 | 08:22 PM
jasongeist's Avatar
i had no idea that it was my cluster gauge the reason y i replaced it was cuz my vss was going out and i noticed that when i have my brights or blinker on and i hit 6000rmp that my car didnt cut out or hit wall. so i have no idea y my cluster gauge caused all that
1.6 EF9
Nov 11, 2011 10:16 PM
bigdantsi
May 14, 2011 07:00 AM
tidalwavez
Jan 12, 2011 12:24 AM
