Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Civic cranks strong, wont start unless
Old Apr 8, 2011 | 02:31 PM
empirejr's Avatar
Default 01 Civic cranks strong, wont start unless
2001 civic 150,xxx cranks and cranks strong but will not start unless given gas, when given gas motor turns over and runs with foot on gas, when foot is taken off gas rpms drop and the motor sputters out..as of right now i've done the following.
-car needs a battery, so i hooked up jumper cables for ***** and giggles..no difference
-checked all the senors around the motor, unplugged and replugged in all of them
I cleaned my EGR valve today but i don't think that relates to the problem at all seeing as i let the car idle for 10 minutes after i re-attached it.- no problems
I'm thinking alternator? fuel delivery? fuel pressure may not be enough? maybe a bad sensor or something..and help would be greatly appreciated..I do plan on taking out the alternator tomorrow and getting it tested.
Old Apr 8, 2011 | 08:39 PM
lazlong's Avatar
Default Re: 01 Civic cranks strong, wont start unless
I would start with scanning for codes. If none, check fuel pressure. It should be 40-47 psi.
Old Apr 9, 2011 | 09:33 AM
It Wasn't Me's Avatar
Have you tried cleaning the IACV? (Idle Air Control Valve)
Tried resetting the ECU and doing the Idle Relearn?
Checked the fuel pressure? (as noted)
PCV?
Vacuum leaks?
allmotorb20R
Mar 4, 2019 07:04 PM
Shanasman12
Apr 9, 2014 08:45 PM
beseman
Nov 15, 2007 12:33 PM
blumpfish
Aug 31, 2006 07:04 PM
StolenTeg
Apr 21, 2005 08:02 AM
