What's up with my antenna?
Old Apr 8, 2011 | 01:09 PM
Will14's Avatar
Icon6 What's up with my antenna?
Hello all, I have a 92 Accord EX and when the antenna is up and it's raining, water gets through the antenna housing into the trunk. I want to install a sub woofer in there so I need to stop the leak. I have fixed all the other leaks. Sometimes the antenna doesn't go down all the way. Do I need a new antenna, motor, or anything else? Where's the best place to get it?
Thanks so much.
Old Apr 8, 2011 | 01:36 PM
specialone70's Avatar
Default Re: What's up with my antenna?
if i were you i would just get a permanent antenna and make sure its sealed with some GOOP sealant or glue. or just seal it with the GOOP and forget about replacing the antenna. also i would seal it from the inside so it doesnt look like crap
Old Apr 8, 2011 | 03:42 PM
slomofo's Avatar
GDD Member
Replace part #23, it's $3.55 and takes all of 5 minutes to replace.
http://parts.sonshonda.com/showAssem...ssembly=287667
Will14
Mar 30, 2011 05:38 AM
porkchop14
Sep 29, 2004 01:59 AM
