What is this switch?
Old Apr 8, 2011 | 11:02 AM
curtie94's Avatar
Default What is this switch?
Hi in my 1991 Honda Accord there is an on/off switch, I was wondering what it was. http://www.flickr.com/photos/61569493@N06/5600756659/
Old Apr 8, 2011 | 11:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: What is this switch?
Pic not working. 94
Old Apr 8, 2011 | 11:56 AM
curtie94's Avatar
Thanks
Old Apr 8, 2011 | 12:20 PM
GhostAccord's Avatar
That is not a standard Honda switch and without seeing where the wires go, it's impossible for anyone here to tell you what it is for. Could be some idiots homemade VTEC engagement switch. Or it could be for fog lights????
Easiest thing would be to follow the wires and see what they lead you too.
Old Apr 8, 2011 | 02:02 PM
curtie94's Avatar
It goes to the aftermarket car alarm, but it doesn't turn it off.
Old Apr 8, 2011 | 02:55 PM
Stagerguy's Avatar
My guess, valet switch.
Snipped
A valet switch is part of most modern car alarm systems.
Suppose you need to lend your car to a friend, or take it to a full-service car wash. Maybe even go someplace so fancy they actually have valets. (Hence the name...) It's not usually practical to give these people the remote to your car alarm -- they're typically kinda big, at least on the scale of things that go in your pants pocket -- but at the same time you don't want the poor bastards to have to listen to your car's pointless screaming. (Many car alarms have a cutoff either to the ignition or the fuel pump, so they'd be screwed, and your car might be damaged as well.)
Enter the valet switch. It's a tiny switch (rarely more than a couple centimeters), tucked away in some unobtrusive location (most typically under the car's dashboard on the driver's side, but occasionally in the glove compartment, or even under the hood in the fusebox). Flip the switch, and the blinkenlight usually goes from blinking to solid, and the alarm is disabled until you flip the switch back.
End Snip
Source: http://everything2.com/title/valet+switch
Old Apr 8, 2011 | 03:35 PM
slomofo's Avatar
GDD Member
Alarm valet switch.
Cheapo DEI brand alarms all have those and 99% of the time, they don't work, but the audio guys install em anyway.
Old Apr 8, 2011 | 04:59 PM
fcm's Avatar
fcm
Old Fart
Because it is an on/off, [SPST] switch, valet switches are normally momentary, [SPST momentary] it is most likely not a valet switch but an on/off for a remote start, either way and as mentioned it is not a stock switch.
Have you checked to see if it is connected to anything yet? 94
Old Apr 8, 2011 | 05:23 PM
curtie94's Avatar
yeah it just goes to a box under the dash that has to do with the car alarm.
VERGOTEx3
Audio / Security / Video
Jul 2, 2010 01:39 PM
PCs99Accord
13
Jun 28, 2007 11:23 AM
ccope07
Jun 28, 2007 04:26 AM
MileHigh
Sep 27, 2003 06:13 PM
GreenD
Sep 15, 2002 02:22 PM
