Are my spark plug wires arcing?
Old Apr 8, 2011 | 07:12 AM
EG6 Love's Avatar
Default Are my spark plug wires arcing?
gt35r B18c 1.98L
i am using a MSD blaster SS coil with MSD cap and rotor. However, i have OE Honda plug wires that after ~600 miles are brown in color. does this indicate that my wires are arcing?
i am suspicious because my tuner said i was getting ignition cut during the tuning process when we tried to turn the boost up from 12 psi to 16psi. after we turned up the boost, i was no longer able to make a complete pull and we turned boost back down to 12 psi and have not had any drivability problems since.
thanks in advance,
doug
Old Apr 8, 2011 | 07:32 AM
eastbay92cx's Avatar
Default Re: Are my spark plug wires arcing?
You can try reducing the spark plug gap, or it is possible that a new/different distributor or an upgraded ignition system will help.
Old Apr 8, 2011 | 08:53 AM
wc4ohio's Avatar
Using a spray bottle with water you can spray the wires (kindof misting them). Do it in semi-darkness. You should see the arcing if there is any. I've heard people say this isn't a good method to use, but I've done it countless times without issue.
wattsdc2turbo
Oct 2, 2007 02:43 AM
Rob.
Sep 10, 2007 07:51 PM
GraphiteMW
Nov 7, 2006 03:55 PM
kevino002
Jun 8, 2005 11:05 PM
shoei
Oct 7, 2004 04:03 PM
