Oscilloscopes anyone?
Does anyone here use an oscilloscope for diagnosis? If so, what model do you use, or have you used? I am looking at these USB oscilloscopes that are around $100 but I've never used one before. Not sure if it's worth it. ???
I use a Pico scope. However if you are new to using a scope take a class and buy a Snap on Vantage Pro. They can be had used for about $1000-$1200. The VP is hands down the BEST scope for beginners to use. Lots of connector views and how to's built in. If you are not an automotive professional, I really dont see what you would need a scope for.
I'd like to get one for diagnosing ignitions pre-obd2 and sensory devices. I'm not a "professional" as in I don't work in a shop, and I have no plans to. But any tool I can use to check the health and operation of electronic components and being able to spot problem sources is a plus for me. I have my eye on a USB pico scope with 5 channels. I have several books that show how to use one for diagnosis, but I'm not sure if a pico scope would serve well for that purpose or not.
I dont know how well lower end scopes perform.
http://www.eevblog.com/2010/03/31/ee...00mhz-ds1102e/
We did this mod to my buddies O-scope and it worked wonders also he had the version with the logic analyzer.
you can use a handheld 2mhz scope for car troubleshooting.
This is one of the stand-alone scopes I was looking at: http://www.tequipment.net/Velleman_HPS10SE.html
It has a 2mhz bandwidth. For a little more, it can be had with 12mhz bandwidth. I'm not sure if this would be usable, in comparison to a USB DSO that can store a lot of recorded data; I'm not sure if recorded data is even necessary, or if this device can record.
http://cgi.ebay.com/Velleman-10mhz-H...item5adb60e3a4
Ive also been thinking about getting one of these to carry in my smaller toolbox
http://www.robotshop.com/seeedstudio-dso-nano.html
the speedstudio dso takes 1 Msps (1 mega samples per second) at 12bit and has an analog bandwith of 0 - 1mhz ......for car sensors this is more then fast enough
Problem with that is you cannot review the info and catch intermittent problems. A modern DSO is plenty fast and the sampling rates are more than enough for any car.
far from a poor choice if you know how to use an oscilliscope properly. digital scopes since they do have a sampling rate and a delay till display they can miss spikes but a random spike here and there usually isnt an issue for car electronics unless the spike is high enough to cause something to trigger.
There are dirt cheap clones of the seedstudio dso nano floating around. Especially if you're capable of assembling it yourself. I have one, but it's been rare that I've actually needed to use it.
correct....an analog scope if your not staring at the screen 100% you can miss something....for cars where your signal is pretty close to being on and off with a slight knee till saturation digital scopes work great and you can datalog and go back and graph later.
the only reason im using them is in testing of some of the ignition electronics ive built for my honda.
http://diagnosticnews.com/tech/autom...pecifications/
*Also you may be interested in knowing that a new Pico scope is on the market that is rated at 80mhz. This speed is necessary for Flexray vehicles that are starting to hit the market.
sweet link, I'll definitely have to take a look at that... but still, i am probably going to keep working on older cars only, so I'm still confused as to what I should get.
Again I cannot tell you, as a casual user, which is the best bang for your buck. But i still suggest taking a scope class for any scope you choose to use.
i've been using an Oscope for quite some time on both nissan's equipment and honda's equipment they provide at the dealer its not bad but i wish it could range faster and attempting to find some of the time and divisions in the book are kind of a pain in the ***.
i have been lately using a friends snap on scope and its quite a wonderful piece, time and divisions built into the module with what you are diagnosing. Probably going to be purchasing one soon, along with a cheaper scope just to play around with.
advantage, bang, buck, honda, ociloscope, oscilloscope, oscilloscopes, osilliscope, pro, scope, snap, snapon, speedstudion, vantage, worth
