Brake pedal sinks almost to floor
Old Apr 7, 2011 | 05:06 PM
curtie94's Avatar
Default Brake pedal sinks almost to floor
In my 1991 Honda Accord my brake pedal only sinks close to the floor when braking for a long time. Should I bleed the lines?
Old Apr 7, 2011 | 05:17 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Brake pedal sinks almost to floor
Your master cylinder could be on it's way to the grave, if that is not the case check your calipers for leaks or any other braking components.
Medinabard's Avatar
yes and check for any leaks in the brake lines
Old Apr 7, 2011 | 11:15 PM
boosted90's Avatar
Start at the easiest thing....make sure there is still fluid in brake booster reservoir (obvious I know).
Old Apr 8, 2011 | 04:43 AM
curtie94's Avatar
I am not losing any brake fluid
Old Apr 9, 2011 | 01:16 PM
503h22jdm's Avatar
then its your master cylinder, i had the same problem in my 95
Old Apr 9, 2011 | 05:01 PM
nus_dogg's Avatar
It's obvious that it's the Brake MC. If the line are leaking, you will not have pressure at all even if you step on the pedal to regain pressure due to air entering the line.
stevescivic
13
Apr 14, 2014 02:23 PM
slowesteg
Suspension & Brakes
Sep 4, 2012 08:24 PM
95GS-R
Jul 18, 2003 08:15 PM
Angry Joe
Jul 24, 2002 05:17 AM
The_In_Kid
Jul 7, 2002 11:45 PM
