Will these two harness's work together??
I have a 88 CRX DX and i need to know if a 88-89 HF under-dash harness work with a 90-91 crx Si engine wiring harness so i can hook up the SI injector resistor box??
[Modified by JDMports, 2:17 AM 9/28/2002]
you can use them togeather but some of the connecters will be different just use some of the connectors from the original dx harness
[Modified by zcpowereddx, 7:19 AM 9/28/2002]
sorry about the mix up Im thinking about the connectors under the dash if your talking about the main connector in the engine bay the one with the resistor box you should be fine with the connections
