CRX b16a1 swap help! wheel hub question?/clutch?
Old Apr 7, 2011 | 09:30 AM
Toallhisdoom's Avatar
Default CRX b16a1 swap help! wheel hub question?/clutch?
Hey guys doing an engine swap for my buddy. He got a 91 crx that were putting a b16a1 in it. were having so many problems trying to figure out what car to tell the parts stores we need parts for. any one know what car the b16a1 dohc vtec engine came out of? Its the JDM engine.
Also will the wheel hubs from an integra fit on the crx?
And the guys at exedy said he ordered the right clutch but it seems to me like theres to much movement between the clutch and the trans axel splines.
PLEASE HELP!
thanks
-colt
Old Apr 7, 2011 | 09:39 AM
SIef9's Avatar
Default Re: CRX b16a1 swap help! wheel hub question?/clutch?
i used 91 integra non abs....
if the crx isnt an si get si knuckles you should be fine and take the dust rings off
Old Apr 7, 2011 | 09:40 AM
SIef9's Avatar
or go to your local junkyard and get the intermediate shaft and knuckles from a DA and just use that setup
make sure its non abs
Old Apr 7, 2011 | 10:41 AM
hatchet_honda's Avatar
the b sereis axles will fit the crx as long as its not an hf. they have smaller hubs, and remove the dust rings on the inside of the hubs. halfshaft from 90-93 teg will work.
Old Apr 7, 2011 | 10:42 AM
and if your getting engine parts say 99-00 civic si. it has a b16a2. axles get them for 90-93 teg.
Old Apr 7, 2011 | 11:57 AM
SIef9's Avatar
i use 94 del sol b16a parts but yeah you should be fine with what we said
savage3006
Dec 31, 2008 05:21 PM
Catch
Aug 27, 2008 09:00 AM
ChinkyChris
Apr 16, 2008 04:34 PM
robbizza
Oct 17, 2006 10:53 AM
H23vtecEG
Feb 4, 2003 10:15 AM
