NEED HELP IDENTIFING Y8 MAIN BEARINGS!!!!!
Old Apr 7, 2011 | 04:02 AM
Radyjr's Avatar
Default NEED HELP IDENTIFING Y8 MAIN BEARINGS!!!!!
I need help identifing these main bearings for my D16Y8 VITARA Motor Buildup. I've done searches and been looking and reading posts on main bearing and can't seem to find anything. To make the story short. Motor had 115,023 on block and i decided to do a vitara buildup since i had the motor boosted this past summer and i want more power. When i tear down the motor and take it to the machine shop for cleaning the guy that i've always talked to says to me ( Thank got you decided to tear down the motor now becuase the the thrust bearings on the motor were pretty worn down. and he shoes me the thrust bearings and i was amazed on the condition. Now he said that he put the main bearings in the box. I'm having trouble ordering a set of main bearings because the honda dealer at work asked me what color are the bearings. i know i need std size because nothing was wrong with the crank but if anybody can let me know what color are these bearing i would be greatly appreciated. There is also numbers on the bearings that i took a picture of just to help out to identify them. Thanks alot Guys. Photos are attached Pictures were from my blackberry. Sorry working of getting a Digital Camera!!!!!!!
Old Apr 7, 2011 | 03:12 PM
Radyjr's Avatar
Default Re: NEED HELP IDENTIFING Y8 MAIN BEARINGS!!!!!
Anybody tell what color these bearing are?
Old Apr 7, 2011 | 06:13 PM
mik101's Avatar
Digital calipers are dirt cheap these days. Would be easy to measure and do a search...
If the bottom end hasn't been worked before the color codes will be on the crank etc.
Old Apr 8, 2011 | 06:05 AM
Radyjr's Avatar
awesome thanks, Do you know by any chance where on the crank the colors will be?
Old Apr 8, 2011 | 06:26 AM
98integralsB18's Avatar
http://www.ek9.org/forum/engine/9479...need-help.html
^Check that out. I'm not sure if it is the same for d-series or what but worth a shot.
Old Apr 8, 2011 | 06:37 AM
http://www.teamxxxracing.com/Forum/s...ad.php?p=10083
Or this, this seems easier to understand and see!
nix94delsol
Nov 13, 2007 05:31 PM
Toneman14
Mar 9, 2006 09:47 AM
itr1244
May 19, 2005 07:40 PM
db2integra
Sep 20, 2004 08:25 PM
ThirdGenLSR209
Jan 23, 2004 02:53 PM
