Transmission & Drivetrain Gearboxes, Differentials, Clutches
D15B SWAP INTO CRX CLUTCH HELP!!! ASAP
Old Apr 6, 2011 | 11:19 PM
CPT Del sol's Avatar
Default D15B SWAP INTO CRX CLUTCH HELP!!! ASAP
I just got a d15b obd-1 longblock from a fello ht member and it comes with a flywheel and clutch already mounted on. My question is do I have to replace the clutch with a clutch for a crx or can I just buy a throw off bearing and slap my si cable trans on.
The right thing to do is replace the clutch but Im low on funds and this clutch has low miles
Old Apr 7, 2011 | 03:50 AM
94EG8's Avatar
Seagull Management
Default Re: D15B SWAP INTO CRX CLUTCH HELP!!! ASAP
If you have an '88 transmission you'll need to replace the clutch, '89 - '91 transmission will work fine though, you'll just need a cable throwout bearing.
ZCSpeed rules
Mar 3, 2014 06:08 AM
CPT Del sol
Apr 6, 2011 10:08 PM
MichealSenior
Feb 17, 2009 12:56 AM
orangeskater
Sep 21, 2008 09:57 AM
Yaa
Nov 12, 2006 05:45 PM
