All in one pressure/temp/etc.. meter/gauge?
Old Sep 27, 2002 | 09:12 PM
vtec.dc2's Avatar
Default All in one pressure/temp/etc.. meter/gauge?
I want to monitor oil pressure and other readouts inside the car. I'm aware of separate single, double read-out gauges out there. for example: http://www.optauto.com/webstore/depa...s.asp?dept=509
1. I wanted to know if theres such thing as all in one. - like some type of lcd display where you can switch to monitor one to few at the time?
2. I assume that factory ecu has to have at least most of in not all the readouts available out there. Wouldn't it be easier to just tap into ecu and see them from one display? VAFC (don't have that), but it gives some of the readouts - is there some type of module with more readouts?
Stuff like Oil Pressure/Temperature Water Temperature, Fuel Pressure, A/F, voltage
Old Sep 30, 2002 | 05:08 PM
vtec.dc2's Avatar
Default Re: All in one pressure/temp/etc.. meter/gauge? (vtec.dc2)
top
Old Oct 1, 2002 | 09:54 AM
Project X's Avatar
You are in luck. It's a new product from Defi.
http://www.defi-shop.com/product/dl/dp/dp_top.htm
Old Oct 1, 2002 | 10:30 AM
vtec.dc2's Avatar
Default Re: All in one pressure/temp/etc.. meter/gauge? (Project X)
Thanks! will check it out
twiztid00002
Feb 3, 2008 06:27 PM
stdefhatch
Mar 20, 2006 03:18 PM
eg:R
Oct 29, 2005 01:17 AM
IGGY
Nov 28, 2001 02:14 AM
