89 civic obd1 b20b swap , weird missing , hesitating issue. HELP
Old Apr 6, 2011 | 06:28 PM
93grayeg's Avatar
Icon2 89 civic obd1 b20b swap , weird missing , hesitating issue. HELP
i have a 89 Si with a obd1 converted b20b , car ran fine for a few weeks . Now when I try and keep my foot steady on the throttle it hesitates and starts to miss..The car runs fine when I apply enough throttle , It doesnt bog or anything like that, As soon as i give it a decent amount of gas it clears up. It did throw a CEL but I turned the car off and It hasnt came back on since...Any ideas? the motor is fresh , only has 30,xxx miles. The dist. I bought used when I bought all the obd conversion stuff. The car has I/H/E . Does have a walbro 255 pump from when it was boosted but it ran fine for the first few weeks
Old Apr 6, 2011 | 07:40 PM
1990edsedan's Avatar
Default Re: 89 civic obd1 b20b swap , weird missing , hesitating issue. HELP
does this happen cold or only when the engine is warm?
Old Apr 6, 2011 | 07:47 PM
93grayeg's Avatar
seems like its a little bit of both , I would have to say a lot worse when its cold
Old Apr 7, 2011 | 08:44 AM
93grayeg's Avatar
anyone?
Old Apr 9, 2011 | 10:08 AM
93grayeg's Avatar
ttt
Old Apr 9, 2011 | 11:51 AM
hybridmiklo's Avatar
chances are if you didn't disconnect the battery, the ecu saved the code. Check it. Other than that all i would think of is o2 sensor. Since this sensor mainly works at idle and half throttle.
zachhthe1
Oct 9, 2013 07:12 PM
nickeynick
Jul 9, 2009 04:15 PM
Bc1r6x
Jan 3, 2007 07:18 PM
aznlaoboi315
Jun 4, 2006 03:02 PM
