need help on slapping a new oil pan gasket
Ok so I'm leaking oil gasket looks torn up. Never did this before so how's the right way to do it? Silicone or not? And how tight? I went to tighten the 1 that's on there now and it just leaked even more so any help?
You clean off the surface real good. Then apply a very thin coat of high heat silicone. Then place the new gasket on, place the pan back up, and install all of the bolts a few threads in at first to ensure the gasket don't shift. Then tighten them up, evenly in a cross pattern.
Thanks a lot 1990edsedan I will try this when I get off work I'm just worried about the gasket shifting hope it goes ok. Either way its better than paying some mechanic $120. Once I do this I will let dry for a long time.
13 - 9 - 5 - 1 - 3 - 7 - 11
17 - - - - - - - - - - - - - 15
18 - - - - - - - - - - - - - 16
14 - 10 - 6 - 2 - 4 - 8 - 12
Freshdot
May 18, 2010 06:52 AM
