fs:totaled ek use car for spare parts lots of extras on the car
Hey guys so unfortunately my car was the victim of a hit and run the other day so now I have a totaled car for sale. It is a 98 Honda Hatch with a 99 front end conversion. The pics make the front look worse than it actually is, the radiator support was not damaged). Car still turns on!
Car has a full working b16a2 (usdm) 99 production year swap
only check engine lights are primary heater circuit and air intake temp (sensor not there)
b16 transmission
-new bearings installed less than a year ago by local shop
-just changed the tranny fluid a couple of weeks ago with honda fluid
act stage 2 clutch 1 yr old
act light weight flywheel 1 yr old
converted ex harness
virgin ecus never chipped or modded (have a pt2 and a p28)
jumper harness for both ecus
t braket
axles
shift linkage
new brushings
b&m short shifter
gsr full disk swap (driver rear not good anymore)
-new rotors and pads (4 corners)
-prop valve
-type are booster
-1"master
-have both itr front calipers plus all replaced dx brake set up
blox camber kit front and back
have stock exahst
also have a tanabe medalion concept g
takico blues
purple edelbrock springs
-vis cf hood a few cracks now
-oem 99-00 bumper (unpainted)
--still good it has a tear in left fender screw hole
--dent was popped out but there is still a line
-stanley sir lights with city lights (lights were new still have no hase on them)
--passenger side the tabs are cracked due to the impact
--driver one tab broke off
-stanley side markers with wiring harness
-new radiator installed at time of conversion
oem si cluster (can reset the mi if you want)
oem dx cluster (can rest the mi if you want)
complete interior (had already taken out the rear but I have it still)
--driver seat is ripped
--never got rid of any of the factory interior parts
The hit made the driver door not open, cracked the rear bumper (lights are ok), ruined a set of volk ce28s (3 tires still good, aprox 3 mo old), and took out the rear driver axle i think the thin civic lower control arm bent so the trailer arm might, stressed on might be good
The car is on a trailer in Santa Maria and is going to get moved to Fresno area soon.
I would like to sell the entire car to one person (so I don't have to take the parts off myself since I do not have time right now). I might consider parting out but it might be a while until I have time to take them off. Feel free to shoot me offers though no set price or prices as of now
b16 transmission
t braket
axles
shift linkage
new brushings
b&m short shifter
-prop valve
-type are booster
-1"master
have stock exahst
takico blues
I want jus the shell no engine tranny. So on n so forth
Pm me price for it n also I will remove engine n parts ii don't want need lmk...
You know how much the lowest you will take for parts is so just put up the prices
