88 civic hatch temp gauge issues
Old Apr 5, 2011 | 07:23 PM
Dpfan's Avatar
Icon2 88 civic hatch temp gauge issues
When my car in warmed up and temp gauge reads around the middle if I turn my blinker on the needle goes to about 3/4 on the temp gauge and bounces, and if I turn on my high beams needle goes in the red and says overheating. Is this a major problem, and if so how do I fix it
Old Apr 5, 2011 | 11:49 PM
90efzc's Avatar
Default Re: 88 civic hatch temp gauge issues
Sounds like you got some wires crossing. Check out the wiring leading from the gauge cluster & your blinkers, under the dash. Someone should be able to explain more in depth. It shouldn't be a major problem unless you can tell that your car is actually overheating.
Enzo jdm FL
Mar 26, 2017 11:29 PM
Alex Ely
Mar 28, 2015 09:16 AM
89Jayda206
Nov 15, 2012 08:49 PM
86RedFoxBodyGT
Nov 6, 2010 06:46 PM
RenoRacing
May 17, 2002 03:42 PM
