Violent jerking while car in motion
Old Apr 5, 2011 | 03:07 PM
203_EM2's Avatar
Default Violent jerking while car in motion
Ok so ive got a b18b1 in a 96 hatch and i took the car out last weekend and when i was in gear at low RPMs the car started to jerk really hard i pushed in the clutch and it stopped. now some people have told me its the clutch/flywheel and others told me no way because its already moving and clutch not engaged. So i need some more input on this. if i shift gears or push in the clutch it stops and only happens at low RPMs 3k-down. i didn't do the swap bought it like this.... and the kid says that it has some sort of stage 2 clutch. but one guy told me its probably a 6 puck because of how much gas i have to give it to take off. it also jerks sometimes when i take off if i don't ride the clutch a little. and yes i do know how to drive stick been doing it for around 5-6 years now. any help will be greatly appreciated.
Old Apr 5, 2011 | 04:15 PM
datsol94's Avatar
Default Re: Violent jerking while car in motion
check your motor mounts or the engine and transmission torque mounts may be torn causing the motor to rock back and forth under a load.
Old Apr 5, 2011 | 04:48 PM
sde780's Avatar
If you're in 1st or 2nd that should be normal. My Prelude did this and nothing was wrong with it, you can usually mellow the jerking by giving it a little bit of gas
Old Apr 5, 2011 | 05:48 PM
203_EM2's Avatar
does it in all gears... highway 5th gear 3k rpm drove like a caddy but city driving was horrible
Old Feb 12, 2013 | 04:32 AM
Rice a Ronii's Avatar
My ek does the same thing.. Only at low RPMs and is worse in bumpy parking lots.. It seems like the clutch isn't grabbing good enough but I want to be sure that is what it is before I buy a new one
Old Feb 12, 2013 | 06:13 AM
sde780's Avatar
If it's that jerky check TPS sensor
eromezab
Transmission & Drivetrain
Apr 26, 2014 08:57 PM
blkbb6
Dec 8, 2011 04:39 AM
ic89
10
Feb 3, 2008 09:21 AM
kornerk12
Dec 20, 2005 05:47 AM
Lauj87
Aug 27, 2005 09:59 PM
