HELP! ! ! ef is surging
so im testing my car at 2000rpm and holding it there, after awhile it starts surging, and im still holding the pedal at 2000rpm. what could be the problem, ive cleaned the iacv but problem still happens, help please thanks. . .
(ill post a video of it asap)
http://www.youtube.com/watch?v=ucrHnTcEqnE
heres the link to a video i recorded of my car with the problem, at 28sec i redid the test and just keep watching to see what happens
Maybe the computer thinks its idle is to hi... Does it surge when driving? I've had similar issues. All it was; the throttle cable was pulled to tight and needed adjusting.
Try looking here for ideas... https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/surging-idle-issue-2909253/
-Hope this helps, good luck!
the throttle cable help a lot, also the idle air adjusting screw, but still surging. other then that my timing is 2 degrees off so im gonna attack that problem soon hopefully
