Central Cal B16a2 motor 4 sale
up for sale is a complete B16a2 motor. 111k miles
the head is from a 1999 civic si and the block is from a 2000 si.
I don't know what year the tranny is but it doesn't grind or pop. transimission will need new clutch.
engine will come with
-Head
-block
-transmission
-manifold
-ecu
-distributor
-axle
-shift linkage
-header
-OBD A1-A2 Conversion harness
-96 EX engine harness
* issues that needs to be address.
-will need new clutch pretty soon.
-engine has check engine light code P0337 (Crank sensor)
-gasket for vtec soleniod needs replace. (does not lead bad, just for if you want a clean looking engine bay)
-speed sensor, you will need speed sensor from b serious motor.
-wire speed sensor connector.
Asking 1200 obo. ..
No parting out.
FYI MOtor is not a stolen motor
Vin # is 1HGEM1159YL055794
vist https://www.nicb.org/theft_and_fraud_awareness/vincheck
input Vin number in for more info.
this motor is from theft savlage recoving. Not Stolen
-Head
-block
-transmission
-manifold
-ecu
-distributor
-axle
-shift linkage
-header
Asking 1200 obo. ..
No parting out.
b16a2, california, complete, conversion, engine, engines, fresno, harness, honda, motor, obd, oklahoma, philippines, sale, transmission
