02 accordSE 4 cyl. wont start in cold weather
Old Apr 5, 2011 | 07:00 AM
kristi-accord's Avatar
Default 02 accordSE 4 cyl. wont start in cold weather
Runs like a charm except in cold weather. dealership cant find a reason.
when its cold it turns but engine will not kick in, you can go back in 5 min. or 3 days later and it starts right back like nothing happened. however i cant depend on it like this. does anyone have or had this problem and could share info. as to how i can fix this. What throws us off is in the hard winter we took it to the dealership and it started for them 5 days and when I picked it up it didnt start the next morning. thank you
Old Apr 5, 2011 | 10:49 AM
MC Slide Hammer's Avatar
Default Re: 02 accordSE 4 cyl. wont start in cold weather
maybe you have a lot of water/ice in the fuel lines, etc.. try buying a bottle of water absorber ("isoheet"?) or something (about 2 dollars) and add that to your tank.
my car would start up briefly and then shut out two seconds later this past winter season. i treated the fuel with the absorber and haven't had that problem since.
Old Apr 5, 2011 | 06:21 PM
Another possibility is the main relay. Soldering joints on that chip board get fractured and develop electrical resistance that is affected by temperature, although usually in hot temperature. Try resoldering those joints or replacing the relay.
Old Apr 5, 2011 | 06:38 PM
mavvrik's Avatar
Very common reasons include:
fuel level
battery life and/or bad cables
starter
ignition
insufficient fuel delivery (filter, relay)
excessive engine wear
fuel contamination
Bad ECM/PCM or main relay
Mine did the same thing and it was a combo of the battery, starter, and plugs (gap was too wide)
crashtest2600
May 14, 2012 02:33 PM
slk08
Dec 1, 2009 04:13 AM
Tizzakowack
Dec 30, 2008 07:16 AM
