which way do i turn my crank pulley
Old Apr 4, 2011 | 11:14 PM
92db2gs-r's Avatar
Default which way do i turn my crank pulley
which way do i turn the crank pulley to make my number 1 and 4 pistons go down? i dropped a piece of lil piece of metal thru my spark plug whole and its just sitting on top my piston. i tried using a magnet but no luck because my piston was up. i might be able to get it out if the piston is down.
Old Apr 4, 2011 | 11:21 PM
djkobe's Avatar
Default Re: which way do i turn my crank pulley
counter-clockwise. you might want to try to shine a light down before moving the crank to make sure its not caught on the side and going to scratch the **** out of your cylinder walls
Old Apr 4, 2011 | 11:28 PM
92db2gs-r's Avatar
i dont think it would be stuck. its the lil piece of metal thats in your spark plug wire it came out of the wire i put it back in and stuck all the wires back in place with no spark plugs lol. then i started thinkin maybe i shouldnt have done that i checked and it was gone
Old Apr 4, 2011 | 11:57 PM
mark@silbernage's Avatar
Like djkobe said, CCW. Going the other way is likely to cause your timing belt to slip a tooth or two and really mess things up.
Good luck
Jimster480
Nov 28, 2010 08:34 PM
Civic-Kids
Mar 10, 2009 02:58 PM
White86CRXSi
May 31, 2005 04:19 PM
T--Rex
Oct 21, 2004 05:49 PM
