Ignition problem car won't start need help
I have a 92 Honda civic dx with a 1.5 soch motor my car was running I started it and had to run up stair so I turned it off ran up came down and now my car won't start I hear the fuel pump turn on so I know it's not that it sounds like it wants to start but won't I have tried to push start but have had no luck I have a brand new baterry just put it in the car so I'm thinking its the ignition but I'm not sure it turns over and cranks but won't start I'm thinking the ignition coil n my neighbor said it might be that to but I want to be sure any ideas would help what can I do to find the problem I'm kinda new with hondas but have some experience I just need to find out what's wrong any help would be greatly appreciated ideas, problem, anything will help thank u for reading
First, make sure it's actually a no-spark condition.
RonJ has a great write-up here:
http://www.hondacivicforum.com/forum...g-spark-74362/
(Ron doesn't mention this, but you should really unplug the fuel injectors while doing this test.)
Test all four wires for spark. If all four have spark, you can rule out the ignition system and move on to the next troubleshooting step. If you don't have spark, get a multimeter ASAP - you'll need that for pretty much any troubleshooting of the ignition system.
While you're at it, crank for 30 seconds and see if the 'check engine' light comes on. If it does, see pdiggitydogg's write up on reading the CEL:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Good Luck!
Looks like RonJ beat me to it.
Should have refreshed.
Good Luck!
^This is a very important point. You don't want to flood the cylinders with fuel while testing for spark.
So I check the dizzy n it seems fine but I pulled out the first spark plug wire n it covered in oil n so is the cylinder is also filled is my head gasket leaking or the valve cover gasket
The oil on your spark plug wires is fairly common. The gaskets between the head and the valvecover wear out and let oil into the space for the spark plug. It is probably not causing your no-start condition, but replacing the valve-cover gasket and cleaning off the spark plugs and wires is a good idea.
Checked all four spark plugs n they have spark but the oil filled the cylinder where the wire gies in to the top so that's a valve cover gasket?
Ok.
If you have bright sparks at all four plugs, you can pretty much rule out a problem with the ignition. The timing could be way off but then the engine would misfire really badly when cranking.
Does the check engine light come on when you first turn the ignition to 'run'? Does it go off after 2 econds? Does it come back on if you crank the engine it for 30 sec?
Have you tried a jump start?
Does the starter sound like it's excited about starting the engine?
If the jump start doesn't work, it's time to troubleshoot the fuel.
You will need to aquire a fuel pressure gauge and an adapter for your engine.
bucknastty
Jan 15, 2012 12:49 PM
hurleyboarder21
Apr 12, 2004 07:22 PM
