*UPDATED* ej1cris909 FS/WTT/WTB Thread (b series, DA parts, AEM, Chrome dipped b20)
I have a decent list of parts i need gone! PICS ARE AT BOTTOM!!
All items are in perfect working condition unless otherwise noted.
Text me at 626-848-1888 if interested
Thanks.
List:
*B18B1 longblock really clean engine BUT has low oil pressure. Knocks when first started then stops after a second.
It also will need new valve stem seals. But when I was driving it, it was smooth. Just I would recommend replacing
the oil pump, main bearings, and new seal kit to be safe. asking: 200 bux
*2 GSR, ITR, B16 CHROME DIPPED Valve cover brand new: 150 ea.
*1 D16 SOHC CHROME DIPPED valve cover: 100 bux
*Red billet AEM spark plug cover: 60 bux
*Red aem oil cap: 30 bux
*MSD rpm setter: 40bux
*B18/20 Idle air control valve with very low mileage: 30 bux
*Long neck b20 Intake manifolds, One comes with fuel injectors and rail, then one without injector: 30bux each
*B20 throttle bodies with no sensors, only the Fast Idle Thermo valve low mileage: 30 bux each
*96+honda/acura Intake Air Temperature Sensors: 20 bux each
*OBD0 Fuel injector set: 20 bux all four
*Random A/C lines off 91 integra: Make offer
*Power steering cooler line: 20 bux
*A/C compressor with bracket from 91 integra (wont seperate): 40 bux
*89-91 civic and 90-91 integra Main Relay: 20 bux
*91 integra Integrated control Unit (bad capasitor): 10 bux
*Random 88-91 civic/crx shifters: 5 bux each
*90-93 integra fenders with sidemarker cut outs 9/10: 60 bux
*90-93 integra hood 10/10: 80 bux
*90-93 integra power steering fluid reservoir: 20 bux
*90-93 integra washer fluid reservoir with pumps: 20 bux
*90-93 integra seatbelt control module: 40 bux
*90-93 integra cruise control comuter, cable, and underhood module: 50 bux
*90-93 integra front right mudflap: 10 bux
*b20/18 upper exhaust manifold no cracks or heatshield, real clean: 30 bux each
*TRADE/CASH: JDM STANLEY one piece headlights 150+stocks (cracked one near the fog housing)
WTT for, or WTB::::
*92-93 front and rear bumpers
*OBD1 p75 ecu
*Obd0-obd1 jumper harness
SOLD:
B18a1 longblock
LS tranny
OBD2 Dizzy
OBD1 Injectors
ES Mount inserts
Both PS units
spoon duracon ****
92 gs wheels
obd1 injectors
Thanks.
List:
WTT for, or WTB::::
*OBD1 p75 ecu
SOLD:
B18a1 longblock
LS tranny
OBD2 Dizzy
OBD1 Injectors
ES Mount inserts
Both PS units
spoon duracon ****
92 gs wheels
obd1 injectors
Rings good in the block? Has it been bored and honed? Im not looking for anything I wanna rebuild. I just threw a rod. Looking for something to just bolt on and go so to speak
Rings seemed good b4 i swapped, idk bout bored and honed but the cylinder walls looked good. The only reason i took the engine out was cuz i got the car for a good price so had extra $$ to do alot of work on it. It had a blown head gasket, but was still running. Old owner let it sit afterwards.
