Obd0-obd1 Conversion No Spark??
Old Apr 4, 2011 | 08:07 PM
waspcrx19's Avatar
Icon2 Obd0-obd1 Conversion No Spark??
Currently have a crx w/ b18a1 swap turbo'ed. Car turns on fine with obd0 pr4 ecu but once I convert it to obd1 it wil not fire up. The ecu is a chipped p75 with a I dont know what program and using an obd1 dizzy td-55u. I bought the harness on ebay and the only CEL i get is code 21 which is for vtec and leaves me to say that the harness works and is doing its job. The Dizzy is wired correctly. If the dizzy is faulty, wont the ecu throw a code for that? Think it could be the chipped ecu causing this? Any help would be appreciated thanks.
Old Apr 4, 2011 | 09:03 PM
efjones9's Avatar
Default Re: Obd0-obd1 Conversion No Spark??
no it wont throw a code for the dizzy. only obd2 types do. just try another dizzy and check to make sure there is fuel
Old Apr 5, 2011 | 06:16 PM
waspcrx19's Avatar
So i have no way of getting a hold of another dizzy so what i did was use a light tester that dad has brand new and tested it on the dizzy's black/yellow wire and it lights up. n-e mores ways of testing it? it is leading me to the chip ecu though...
Old Apr 5, 2011 | 06:33 PM
waspcrx19's Avatar
And fuel pump primes and everything is good. just no spark.
Old Apr 6, 2011 | 10:40 AM
waspcrx19's Avatar
bump
Old Apr 6, 2011 | 05:32 PM
waspcrx19's Avatar
bump anyone? need to get it tuned!
Old Apr 6, 2011 | 07:10 PM
sh!ft's Avatar
Who the fack changed my title?!
obd0 dizzy's are different from obd1's. why you think you have to use a vtec dizzy for a z6 when converting and not just an a6 one? different sensors and different obd versions.
Old Apr 7, 2011 | 07:27 PM
waspcrx19's Avatar
Icon3 Re: Obd0-obd1 Conversion No Spark??
What are you talking about? My question is basically if no spark can be caused by buying a used chipped ecu that has never been used in my car. Im sure my jumper harness is connected good. I will have to test my ICM from dizzy but I doubt it will be bad.
Old Apr 7, 2011 | 07:36 PM
Silverfoot88's Avatar
soooo... did you switch it back over to obd0 and try that? double check your connections, i mean, as stupid as i may sound saying it, it's one of those facepalm fixes. if not, ignore me.
Old Apr 7, 2011 | 07:42 PM
waspcrx19's Avatar
If I switch it back to obd0 it will start. No problem. I went and check dizzy connections and everything is fine. I mean wtf man i cant get no spark for ****. The dizzy was bought used but looks new as hell. im braggin on the ecu since it was chipped for turbo on another application. But mine is turbo as well but different setup.
Old Apr 7, 2011 | 07:43 PM
waspcrx19's Avatar
HELLPP!!
Old Apr 8, 2011 | 05:45 AM
213374U's Avatar
0x5359-0055
Community Builder
One question (amazed nobody asked yet)... why the hell are you running a "chipped" ECU when you have no idea what the map on said chip is? You could be running one of those uber badass eBay "Spoon" chips that nets like 70HP!!!!
Find a friend and swap ECU's to see if this fixes your problem.
Old Apr 8, 2011 | 04:33 PM
waspcrx19's Avatar
Post Re: Obd0-obd1 Conversion No Spark??
Its a good ol atmel chip. And All I wanted was the car to fire up after I did the conversion to verify everything went well. Guess no spark is the problem at the moment.
Old Apr 8, 2011 | 08:54 PM
waspcrx19's Avatar
Anyone?
Old Apr 9, 2011 | 06:47 AM
lazy14's Avatar
u got all the clips or obd1 injectors and eliminate the resistor box? may seem like a dumb ? but it could have sumthing to do with it
Old Apr 9, 2011 | 02:28 PM
waspcrx19's Avatar
Im running dsm 450 blue tops brotha I need the resistor box. Anyway, thanks for the info and helps guys, turns out to be that it was the ignition coil. I replaced it and it fired right up.
91sedan_kid
Jan 8, 2010 09:39 PM
neofreak
May 20, 2007 06:17 PM
neofreak
May 20, 2007 06:16 PM
gutted
24
Oct 5, 2005 08:11 AM
91civicEX
15
Sep 3, 2003 10:33 PM
