B16a CEL issue! Really odd.
Okay, so to start off, I have a 92 Integra w/ a B16a swap. The block says its from a 1990, so I assume its obd0, but it may be obd1. I have no idea because I didn't do the swap. My ecu is a p28.
Anyway, I have a CEL, and there isn't a light on the P28 for me to read. I read on another forum that there is a blue socket between the kickplate and glove compartment that I can jump to read the codes from the actual light in the dash. Problem is, I can't find that light for the freaking life of me. I've searched multiple times, and can't seem to find it anywhere. I need to figure out whats going on with my car though. Anyone else have this problem? Maybe there's some other way for me to check?
If you don't have a CEL light on your cluster, then how do you know if you have a CEL?
If you're running a P28, then somewhere along your wiring has been converted to OBD1.. It could be a jumper harness, or it could be the entire harness. If you jump the two spots mentioned, your CEL itself will blink in a sequence. That's what you have to watch for.
Yeah thats what I'm trying to do. And I DO have a CEL in my cluster. There isn't any lights on the ECU though. And thanks. I figured it was OBD1 but I wasn't 100%. Any idea where the jumper harness may be?
I have that thread bookmarked loll. I'm gonna go look again in a minute just to see if maybe, maybe somehow I missed it. I'm really hoping I did. And I know the PR3 has a light on the actual ECU, and I'm pretty sure there's an obd1 one that does too.
when you jump the 2 wires you are reading the blinks of the check engine light on your gauge cluster not the ecu. some OBD0 ecus have the light on the ecu that you read.
I FOUND IT! It was literally a pure stroke of luck. It was hidden down behind my ecu sorta, it wasn't a blue plug and the wires weren't the color they were supposed to be. I just jumpdr it because it was the only thing that I could find so I figured **** it. Anyway it's for my TPS and my ELS. I have no idea what the ELS is at all but I'm researching it. I'm hella stoked that I found it loll.
What code is for the ELS?
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
67 Catalyst low efficiency. (same as P0420)
70 Automatic Transmission Malfunction w/AT Controls
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Evaporative Emission Control System insufficient purge flow
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
Its 20. Same as ELD. I read the DA's don't have an ELD though. I also read that I can pull a under hood fuse box off of a G3 and it has the ELD, and I can just replace my fuse box with the G3. That doesn't sound right to me though. Any suggestions? Maybe there is a ELD?
I found this..
http://hondaswap.com/civic-del-sol-e...etector-76522/
Seems like there's a bare wire that may cause a short where the intake is bolted to the block. Also replacing your fusebox seems to do the trick as well.
Cool thanks man! I'm about to go check and see if thats possibly what's causing it. I read that sometimes when a swap is done the ecu will throw the 20, but only when you're checking the ecu codes.
TwoKSiR
Dec 21, 2009 11:17 AM
