civic problems!
So there's been a lot of problems with my89 ef, with the d15b1, Ill list everything. any help would be greatly appreciated.
Fuel pump went out, so i replaced that and the filter.
after tha ecu was throwing a code for the tdc sensor so I got a new dizzy.
Starter went out.
Replaced the timing belt.
new injectors and ecu.
all the vacuum lines are brand new.
last week when I tried to drive it, as soon as I let off the clutch the car died but it's getting gas to the injector. (dpfi)
and now the starter won't even kick on even though the battery has a full charge. last week it was throwing codes for injectors, vss, and eld sensor, And right now it's throwing codes for eld sensor and and lock up control solenoid valve, but I never replaced the vss. (that's why I replaced the ecu)
Thanks for your time.
Starter went out.
from_zer0
Oct 13, 2003 05:20 PM
