hard to start del sol
hi well i have a 93 honda del sol and this problem just started since last thursday, when i go to turn it on it cranks and everything but doesnt turn over it sounds like it chokes and it sounds like it wants to start but it doesent and then dies...need to fix asap and cant figure out what it is any help i would appreciated
I have a 93 del sol si D16Z6 auto and had to replace the fuel pump recently.
When you turn the key to the first position pause and listen for the whirrr of the fuel pump. It's easy to hear in a del sol because the fuel pump is right behind your seats under the plastic cover. If you don't hear it the problem is probably the pump.
No. You hear it from behind the seats. The fuel pump is inside the gas tank behind the seats under the plastic fascia. For access take off the center console plastic from the stick shift back. Then take out the plastic compartments behind the seats.
DarkGriffin3156
11
Nov 21, 2021 05:33 PM
guitarma
Sep 26, 2011 12:46 AM
unstopabledj
Jul 20, 2003 04:15 PM
