90 crx si dash & harness swap into 88 crx si ???
okay i recently bought a 1988 crx si that came with a 1990 crx si parts car. I want to use the nicer 90 gauge cluster in my 88 si but without having to rewire the thing. If I swap the ENTIRE 1990 si dash and dash wiring harness from the parts car over to my good 88 crx si will the dash harness an everything then be direct plug in with my 1988 crx si or no??
As long as you swap everything over from the 90 Crx you shouldn't have problem. You may have to do some modding on the harness at the doors. Make sure you have a complete 90 engine harness because your 88 WILL NOT work
red_EF9Si
Oct 25, 2008 02:43 PM
CJ407
Jul 17, 2008 01:47 AM
