96 LX D16Y7 auto to D16Z6 manual - Transmission mount woes
Hey. I am a bit new with this stuff but for the most part I AM learning. I am converting from a D16Y7 AUTO setup to a D16Z6 MANUAL setup.
I ran into a issue with this mount. How do I go about bolting it up to the frame or what would I need to do/buy? Thanks.
Note: I attached a picture of the red 94 cx hatch bay and the blue is 96 lx civic bay which is mine for comparison.
You need the bracket and mount for a stick shifted 96 - the 94 uses a different arrangement.
http://www.hondaautomotiveparts.com/...T+ENGINE+MOUNT
#2 and #6 in this image, plus the associated hardware.
I don't think you can use your mount at all - you need the 96-2000 ones.
Btw, the clutch line for a '96 - '00 is different than the '92 - '95 as well, it uses a shorter hardline and a longer rubber flex hose.
getnasty
Nov 17, 2005 12:56 PM
