S2 tuner stage 2 or stage 3?
Just trying to get a general idea as to which set of cams I should get for my b16a? It is going to have CTR Pistons with flat valves and a mugen head gasket to raise compression; I'm shooting for upwards of 12.5:1 on 93 pump gas-- which set of cams would be better than the other and why?
And no, I'm not looking to get pro 1s or 2s-- I want to be as easy on my valvetrain as possibly while daily driving while still having a car that screams at 9k+ rpms...
As far as other relevant information goes...the head is going to be port and polished with supertech valvetrain, has a skunk2 intake manifold, will be receiving a 70mm throttle body.
Let me know if I missed anything, thanks for thoughts+opinions.
Jim
Jim
12.5-13:1 isn't enough? If you go much higher you lose the need for spark plugs pretty much lmao. Approaching diesel compression levels. What compression would you recommend for stage 3? And stage 2?
even with 12.5:1 on a little b16 the stage 2 is plenty big enough
Much appreciated!
Jim
alexthegrinch
13
Jun 17, 2009 05:08 PM
Blazin Si
Feb 24, 2004 01:43 PM
