5 lug conversion kit
hello guys,
I would like to know if a complete 5 stud conversion kit from a Accord will fit my EG?
I mean if the rear control arm from the accord will perfect fit? (like the 5 stud conversion kit from a 98 ITR)
thank U ^^
thank U ^^
Front calipers you can use, rear calipers also appear to be the same as ITR based on the number, you can't use the knuckles or hubs though. '97 - '01 CR-V knuckles are the same as JDM '98+ ITR knuckles, but but like the JDM ITR knuckles you must use '98+ JDM ITR axles.
For daily driving it doesn't seem worth the trouble but for certain races would it benefit for safety to have the extra lug? 4 lugs...1 goes out you're screwed?...5 lug...1 goes out you can at least be safe for a little bit till you can fix it?
A long time ago, people used to do a 5 lug swap mainly because there were more wheel choices. Believe it or not, there weren't always 5 billion wheel choices for 4x100. Now that wheel manufacturers are producing more styles of wheels, the only REAL reason to go 5 lug is for the ballin' status, IMO. Pardon me, I'm OLD SKOOL.
I'm sorry, I was talking early to mid 90s when my friends did some custom fabrication to put Acura Legend 5 lug on an EF to get the wheels they wanted... rotas huh? What about xxr? Enkei? Tenzo? MB? Axis? Motegi? Drag? ..... could keep going for a looonngggg time, but I think you get it. Yeah, there were some sweet old skool wheels back then, but nowhere near as many options and styles as there are now.
hy guys, ty for all your answer, I ask you that because, when I bought a complete ITR 5 stud conversion for my EG, the seller sent a complete Accord 5 stud conversion... )=
1000 bucks waste, and he does'nt want to give my money back, so I try to find a way to use this...
also, I would like a 5 stud conversion kit because of the rear brake disc and the bigger disc to the front.
I presume that I have to check for the rear knucle and hub if I want to use the calipers...
so lazy
Nov 20, 2008 11:17 PM
.jacob
25
May 13, 2004 08:40 PM
