NEED A LITTLE GUIDENCE.
Now I know this has been discussed befor but I need to make sure I'm clear on things.
Ok the car- 89 hatch Dx. Auto
Motor- D16Z6.
The car has yet to have the dpfi-mpfi done. It's still all 100% stock. I am in the process of pulling out the old motor and trans. I am converting it to 5 speed and swaping the motor for a D16Z6. I seem to have the auto to 5 speed conversion figured out. The whole dpfi-mpfi is still a little confussing. Now my question is, Do I follow the steps for converting dpfi-mpfi if I'm using the stock harness off the D16z6? This harness is already mpfi. All the write ups I find are for converting your dpfi harness to mpfi. As I asked before, do I follow one of these right ups if I already have a mpfi harness? I'm using a P28 ECU out of a 5 speed car. So do I still have to re pin the conector at the ECU? Also if someone could help me on what I need to do to prep the D16Z6 harness for it to work in the car?
Motor- D16Z6.
Yes im going OBD1 and yes i know i have to use a jumper harness at the ECU. I will also be using the OBD0-OBD1 jumper at the dizzy. Ok, I thought you did use the Z6 harness. What I'm trying to avoid is cutting, splicing and adding wires to the Dx harness. I also have a stock Si/Hf harness. If I used that with the OBD0-OBD1 ECU jumper harness, would I still have to cut, splice or add wires at the ECU?
