Feels like its hitting a wall
Old Apr 3, 2011 | 10:50 AM
cetcivic's Avatar
no one wants to hear the truth
Default Feels like its hitting a wall
Need helpful advice and input only,thank you in advance
Vehicle:2000 civic ex
Motor:95 LS
Ecu:LS chipped
Symptoms: its gotten worse it now does it on start up engine cold,driven or not,pressing the gas at about 2-4k rpms it bogs and chokes.it won't go any higher like if the rpms hit a wall.I have to shift up .ITS SCARY DRIVING THIS WAY BECAUSE ITS KIND OF RANDOM AND WHAT IF IT HAPPENS WHILE IM TRYING TO PASS OR CHANGE LANES?
Here's what I know:
-the previous owner(s) are not too bright
-02 and knock sensor not functioning but I have no cel w/ chipped ecu
-i have tried 2 other ecus w/ same results except w/ cels
For 02 and knock sensor
Here's what has been changed:
-distributor
-throttle body
-spark plugs
-valve cover pcv
-gasoline:now using 92 octane
-oil(twice since symptoms began)
-cleaned iacv and fitv on old throttle body
-valve cover gaskets(found oil in spark plug tubes)
Any help greatly appreciated.trying to get it running right for honda day atco
UPDATE:it was the TPS..replaced it and calibrated..problem solved
thanks to all who helped with advice and suggestions...greatly appreciated
Old Apr 3, 2011 | 11:47 AM
shogee's Avatar
Default Re: Feels like its hitting a wall
seems like a distributor
Old Apr 3, 2011 | 12:06 PM
lil_cook97's Avatar
Motor:95 LS
Ecu:LS chipped
Symptoms: usually once the car is warm,driven or not,pressing the gas at about 3-4k rpms it bogs and chokes.it won't go any higher like if the rpms hit a wall.I have to shift up .
Here's what I know:
-throttle body
-spark plugs
-valve cover pcv
I drive a 94 Dx with a b16a and mine does this too! For whatever reason i don't understand. But yeah like what that other guy said look into your dizzy first. Second, check your throttle cable...might be like getting stuck...so make sure its tightened. 3rd, change out your o2 sensor, their relatively cheap. Oil in the plug, mean you need to change out your valve cover spark plug gasket....which might cause fouling.
Old Apr 3, 2011 | 12:12 PM
vartok's Avatar
It kinna sounds like "limp mode" I think a bad O2 sensor can force the ecu to do that, so i would change the O2 sensor first.... not sure about the knock though.... i know it can cause it in a stock ecu but most of the time, chiped ones have that removed.
Old Apr 3, 2011 | 01:52 PM
zeroek's Avatar
Check Throttle position sensor. My 97 hatch did that to me. Unplug that tps and drive it after it's warmed up and see if the problem stops.
Old Apr 3, 2011 | 03:20 PM
cetcivic's Avatar
Thanks..I'll see if I can borrow one
Old Apr 3, 2011 | 03:30 PM
cetcivic's Avatar
-gonna check the distr
-throttle cables good
-i changed the vc gasket and grommets
-thanx for the +input
Old Apr 3, 2011 | 03:43 PM
cetcivic's Avatar
I found 3 02 sensors that don't fit..smh
I don't think its limp though..I've had cels before and the car didn't choke up like that..thanx for the + input
Old Apr 3, 2011 | 03:48 PM
cetcivic's Avatar
I changed the whole throttle body..but I'll check that..thanx
Old Apr 3, 2011 | 04:06 PM
shogee's Avatar
check the dizzy, once the engine is warm, it can short out some of the sensors in the dizzy or the icm in the dizzy can short
Old Apr 3, 2011 | 07:41 PM
cetcivic's Avatar
thanks..im definitely gonna try to obtain another distributor somehow to see if thats the cause..
Old Apr 3, 2011 | 07:55 PM
mavvrik's Avatar
Bad knock sensor will do that to ya. Bad knock sensor will also immediately throw the ECM into limp mode
Old Apr 4, 2011 | 07:18 AM
jakfrost84's Avatar
Had the same problem with my H. Went to auto zone bought a universal o2. Wired it up runs fine.
Old Apr 4, 2011 | 07:22 AM
Jimster480's Avatar
Sounds like your TPS isnt calibrated right or your fuel pressure is too low. I had the same issue the other day with my new motor on my old tune. First I recalibrated the TPS and it fixed it mostly but it was still lean (it would break up a bit after 4k) so I turned up my fuel pressure and it was all good.
Old Apr 4, 2011 | 07:27 AM
boostedb20ek's Avatar
X2. Get tps calibrated.
Old Apr 4, 2011 | 08:28 AM
demo024's Avatar
Having the same problem with my 96 ej8 b20v.... Above 4k it cuts out for a second then wants to go again. but if you're hitting a wall i would check dizzy, check the dizzy shaft and gear at the end, i had this problem once and the gear at the end was almost decintagrated and that shaft was broken... Could also be a bad Cat or fuel issue. I belive mine is fuel now. How do i turn up fuel pressure without an adjustable fuel pressure regulator ?!
Hope you fix the problem !
Old Apr 4, 2011 | 02:45 PM
shogee's Avatar
By taking off the little vacuum line to the fpr, it'll supply full pressure but won't be much different, but I'm guessing that's not your issue, any cels?
Old Apr 4, 2011 | 02:59 PM
demo024's Avatar
Only Cel i have is for the VSS. Would that cause this problem ?
Old Apr 4, 2011 | 03:07 PM
grumblemarc's Avatar
The Grumpiest
Talk about a thread jack.
Old Apr 5, 2011 | 12:57 PM
demo024's Avatar
Sorry if you ^^ feel that way ... I gave my advice to the thread starter, and asked one simply question got the reply i wanted and he asked a question so i gave him the info. From now on ill just pm. Not looking to argue or create problems we are all on here to help eachother. Sorry.
Old Apr 6, 2011 | 07:48 PM
cetcivic's Avatar
I'm gonna look into this..I think my fp is fine but not sure about the tps..thanx for the insight
Old Apr 6, 2011 | 07:54 PM
cetcivic's Avatar
Changed out the distributor and crossed my fingers...ahhhh..still the same..but thanx for the + input and good luck w your issue as well
Old Apr 6, 2011 | 08:08 PM
INVN01's Avatar
Make sure the TPS and MAP sensor plugs are not switched. That too could cause that problem.
Old Apr 6, 2011 | 08:27 PM
civicsmoke's Avatar
-tps should throw a code but it's worth checking out its easy to do. Also just so you know, it is essential that the voltage increase smoothly from closed throttle to wide open throttle, if it doesnt replace. But you replaced the whole throttle body. so its unlikly but still possible.
-Also make sure your grounds are good and clean and tight.
- what condition are your spark plug wires in?
Old Apr 7, 2011 | 04:35 AM
cetcivic's Avatar
I'll check that later when I get off work..thanx
