What aftermarket radiator are you using?
Old Apr 3, 2011 | 02:08 AM
TOO MUCH TORQUE's Avatar
Default What aftermarket radiator are you using?
picture says it all about my oem radiator. its starting to leak i think..there is coolant in the form of goo along where the plastic and aluminum meets.
how long do you think this radiator will last?
Looking for a radiator that doesnt require any modification, is sturdy, and can mount the condenser fan too. any suggestions?
Old Apr 3, 2011 | 04:58 AM
BlueIntegraBoy's Avatar
Default Re: What aftermarket radiator are you using?
My radiator did the same thing. I am using a C&R Radiator. Perfect fit. The only thing if you'll need to run aftermarket fans, and you know from this point it is not straight PnP.
Old Apr 3, 2011 | 07:11 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
I will go with a 94 Integra... http://www.usaradiator.com/ACURA--INTEGRA--1994.html 94
Old Apr 3, 2011 | 10:42 AM
did you just replace it as precaution ? dont know how long mine has been gooping out like that.
Old Apr 3, 2011 | 12:17 PM
It was leaking pretty badly. I would have a small pool of coolant on top of my fan shroud.
Old Apr 3, 2011 | 12:35 PM
Spawne32's Avatar
radiator barn double row heavy duty brass/copper
Old Apr 3, 2011 | 03:40 PM
dc4teg95's Avatar
Im using a cx racing aluminum radiator. Have been for year and half with no issues. Got it off ebay for 100 shipped and came with 2 12 inch slim fans. But the cap to me was questionable so I ordered a skunk2 cap. But you have to get a cap for a Nissan or even a gsxr or whatever is the round shape and not the oval type like honda uses
Old Apr 3, 2011 | 04:11 PM
sayanything's Avatar
im using a CSF radiator, picked it up new for around $100. It does have the plastic tanks, but has been holding up for 15K miles + no problems.
Old Apr 4, 2011 | 04:42 PM
so you wouldnt know if it takes the oem fans?
is it the full radiator?
Old Apr 4, 2011 | 05:10 PM
dc4teg95's Avatar
Its a full side radiator. You could probably use OE fans but if it comes with slim fans I would just use them instead and wire them push/pull depending on if you put them on the front or back of the rad
xluigix47
Dec 21, 2012 09:07 PM
aasaa666
Oct 22, 2007 08:15 PM
MiracleWhip
Apr 28, 2007 11:38 AM
Herbie
Nov 6, 2006 02:38 PM
