using a switch for ecu pin connector
Old Sep 27, 2002 | 04:24 PM
photonjedi808's Avatar
Default using a switch for ecu pin connector
I have a 90 crx si w/mini-me
I know when you adjust your timing you have to jump the ecu connector in the passenger side kick panel. I just got an MSD SCI and also an msd timing adjuster. It's going to allow me to adjust my timing from the driver's seat via a ****. I was thinking of splicing into the 2 wires that go to the ecu connector and running a switch next to the MSD ****. Then any time I want to mess with my timing I would just flip the switch then turn the **** to advance or retard.
what do you guys think of my idea? will it work?
Old Sep 27, 2002 | 04:32 PM
spcmotorsports's Avatar
Default Re: using a switch for ecu pin connector (photonjedi808)
im not familiar with the msd timing adjuster but , bro it sounds pretty kool to me, just how do u know what u set your timing to when u move the ****?
Old Sep 27, 2002 | 04:41 PM
Default Re: using a switch for ecu pin connector (spcmotorsports)
I've thought about that. I guess I really wouldn't know what the timing was actually set at. Just would have to go by my butt dyno or maybe a GTECH and listen for pinging. Or I could always carry my timing light with me
[Modified by photonjedi808, 1:49 AM 9/28/2002]
eg grom
Jun 25, 2009 09:27 PM
umair
Oct 16, 2008 10:34 AM
flanker
10
May 23, 2008 09:02 PM
the.hamburglar
Oct 14, 2004 11:37 AM
