Bolt nuts broke off
Old Apr 3, 2011 | 12:37 AM
teepo112's Avatar
Default Bolt nuts broke off
Hi,
I tried to take off the heat shield to replace my o2 sensor. the bolts were rusted and broke off and now they're flush with the manifold... does anyone know how to get them out? thanks.
Old Apr 3, 2011 | 03:13 PM
02 accord's Avatar
Default Re: Bolt nuts broke off
Drill them out.
Old Apr 6, 2011 | 09:21 PM
75aces's Avatar
drill the bolts and then tap.
Old Apr 6, 2011 | 11:13 PM
mavvrik's Avatar
Like they said^^
Drill and tap
Old Apr 7, 2011 | 04:38 AM
nus_dogg's Avatar
I hate that when it happens.
Old Apr 15, 2011 | 10:02 PM
teepo112's Avatar
i can't fit the drill because it's a tight spot. Any ideas?
Old Apr 15, 2011 | 10:19 PM
02 accord's Avatar
Yeah, get a right angle drill.
Old Apr 16, 2011 | 07:37 AM
WilloughbyCoupe's Avatar
Or a Dremel. Used one many times in close quarters to grind out enough of a broken stud/bolt in order to get an extractor inserted.
Note for the future: PB Blaster or Deep Creep applied the day before a project makes life sooo much easier. If a nut isn't hard to access, I spray penetrant, let it soak, wrench the nut a little, back and forth gently, let it rest, spray again, wrench it and so on.
I've never re-assembled a fastener without an appropriate substance; anti-seize, grease,oil, silicone spray...
Good luck!
Old Apr 16, 2011 | 10:58 AM
chikin pickle's Avatar
Just leave it off. Won't hurt anything.
Old Apr 16, 2011 | 01:27 PM
nus_dogg's Avatar
^^ x2! I wouldn't bother with it.
Old Apr 16, 2011 | 01:39 PM
teepo112's Avatar
thanks guys
civic46
Jan 19, 2009 05:53 AM
tpot90
Apr 5, 2008 09:46 AM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
AndrewD
Jan 22, 2005 12:10 PM
