Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
outer tie rod end castle nut size?
Old Apr 2, 2011 | 05:15 PM
jaysonl's Avatar
Icon2 outer tie rod end castle nut size?
Was wondering if anyone knows the size of the outer tie rod end castle nut for a 2001 civic?
and if u could post a link of where i could buy it?
im on maui and no one on this island seems to have it.
Thanks in advance!!
Old Apr 2, 2011 | 05:36 PM
MindBomber's Avatar
Default Re: outer tie rod end castle nut size?
I tried to replace the outer tie rod castle nut too, none of the local parts stores could supply a matching one, so I needed to buy a replacement.
Old Apr 3, 2011 | 03:57 PM
jaysonl's Avatar
do u have a link of where you bought it or did u buy it from your local honda dealer?
Old Apr 3, 2011 | 05:34 PM
MindBomber's Avatar
When I say replacement, I meant I needed to buy an entire new tie rod. I should have been more specific.
Old Apr 4, 2011 | 05:53 AM
honda.lioness's Avatar
Do you mean part 23 in the image below? If so, it is 10 mm nominal diameter.
Does Maui have a Honda dealer? If so, ask the dealer.
Else I think one of the closest online OEM parts dealers on the mainland would be http://www.sanleandrohonda.com/honda-estore.htm
The part is listed under chassis then p. s. gear box.
Old Apr 4, 2011 | 07:07 AM
It Wasn't Me's Avatar
Indeed. I had thought it was 12, so I double-checked this morning with a digital caliper.
I don't know what the thread pitch is, though, someone appears to have nabbed or "misplaced" my gauge.
Old Apr 4, 2011 | 10:58 AM
I think you were thinking of the lower control arm castle nut (as you probably already figured out), 12 mm diamter x 1.25 pitch. This is a "super fine" pitch.
Not sure but if forced to bet I would say 1, which is super fine for 10 mm diameter.
EG9_808
Jan 21, 2011 04:45 PM
lmananT
Oct 21, 2008 09:39 AM
h22_crx
Nov 12, 2007 10:11 PM
yOnKiNaToR
May 17, 2005 11:46 AM
